how to remove abs sensor if sort of seized
Discussion in '1st Gen. Tacomas (1995-2004)' started by ivan ny, May 6, 2021.
  1. May 6, 2021 at 5:50 PM
    ivan ny
    ivan ny [OP] Well-Known Member
    2003 2.7 manual ext.cab
    bad front bearing is there a safe way to get abs sensor off if it’s seized destroyed it last time I did this job
  2. May 7, 2021 at 9:10 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Well, being that you're replacing the front wheel bearings, you could remove the four bolts holding the spindle to the lower BJ, remove the CV axle from the hub, remove the oil seal, and then push the sensor out from the inside, then proceed with removing the spindle as normal.
