How to remove and install alternator.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Regz808, Jun 24, 2020.
  1. Jun 26, 2020 at 10:58 AM
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    changing the battery in the 2016 new escapes is freakin LOL
  2. Jun 26, 2020 at 11:12 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Thankfully i’m not familiar! Finally escaped the wrenching game a few years back
    Edit: wait, battery? It’s not so bad. More the concept of having to remove the wiper cowl is stupid as hell. (Iirc?)
    (For some reason my brain jumped to alternator)
    fiftyxp[QUOTED] likes this.
  3. Jun 26, 2020 at 5:26 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    He isn’t wrong for the best / perfect world scenario, but so many alternators aren’t really upgrades and you seem to be looking for a cheaper option. Assuming you have adequate gauge wire to your amp, a Cap is probably the best cheap option as it’ll let the voltage recover In the rest of the system and you can pinpoint what / where you want the excess “Capacity” to be stored and used for, where as with a battery or alternator you can’t. If your system couldn’t hit the volume you wanted, that would be a whole different ball game. But you description was just the bass. Ie spike voltage.
  4. Jun 27, 2020 at 12:25 AM
    Regz808
    Regz808 [OP] Member
    Regz
    2017 Toyota Tacoma SPORT
    I heard a lot of bad things about running a cap.
    What’s your set up??and how many watts are you running?
  5. Jun 27, 2020 at 7:49 AM
    su.b.rat
    su.b.rat broken truck
    i have an Alumapro capacitor and it has always performed as intended and consistently. i had regular & predictable light dimming before i installed it, and zero after. i also replaced the battery from stock to Odyssey at that time.
    i have a mild SQL setup with no rears to keep the mud out. I'm currently running 1100W on paper, 600w bridged to stereo up front and a 500/1 on the sub.
    https://www.tacomaworld.com/threads/daves-drivers-truck.659667/#post-23055721
