how to remove and intall pitman arms?
Discussion in 'Solid Axle Suspension' started by fireturk41, May 14, 2011.
  1. May 14, 2011 at 9:48 AM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    anybody know how to remove and install pitman arms, i messed mine up and this is onething i have no idea how to replace.
  2. May 14, 2011 at 9:55 AM
    Hardwater
    Hardwater Well-Known Member
    Great Falls, MT
    2011 MGM TRD AC
    1.5" Add-A-Leaf, Toytec Coilover kit @ 2", LR UCA's, Bilstein 5100's all the way around, ProComp 7032's, 265/75 16 Duratracs, bed mat, Weather Techs Digital Fit Floor Mats, Wet Okole Seat Covers, Satoshi
    I never worked on a Tacoma's... But, on most every other vehicle, you need a pitman arm puller, you should be able to rent one from autozone. Spray the hell out of it with penetrating fluid first, some times they are a real pain in the arse to break free.
    To install, you just slide it on and tighten to torque, which is usually rather high, so you'll need a large torque wrench.
  3. May 14, 2011 at 10:06 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    thanks, i have all the tools, just wasint sure how to get it back on the steering box haha, i should have all the parts in the middle of the week, ill post back with pics
  4. May 14, 2011 at 10:22 AM
    Hardwater
    Great Falls, MT
    2011 MGM TRD AC
    If you have your gear box off, just make sure that pitman arm goes on the same way it came off or you might get one hell of a head ache. Some pit man arms can go on 3 or 4 different ways, not sure about the Tacoma.
    It may seem like a silly thing to say, but if you rebuilt your gear box it's easy to lose track of where it was.
    It's all pretty simple, good luck.
  5. May 14, 2011 at 10:25 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    the gearbox is still on the truck, i was gonna take a paint marker and make a line from the box to the arm and then duplicate it on the new one, although i thing the yota arms have splines that match up, 4 that are flat to be exact, i think
  6. May 14, 2011 at 10:35 AM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
  7. May 14, 2011 at 10:38 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    lol lemme get home this afternoon, if i remember
  8. May 15, 2011 at 9:42 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    got pics, just an fyi, a gm tie rod end will not fit in a pitman arm with a hole for an fj80 end, no matter how much force you put behind it...oops
    and it pops right off wih the puller
    but here is pics of my steering set up, everything is above the leaf springs
