How to remove antenna fron 2008 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lalosr17, Aug 19, 2017.
  1. Aug 19, 2017 at 3:53 PM
    lalosr17
    lalosr17 [OP] New Member
    LA
    2008 Silver Tacoma Pre-Runner V6
    None
    I searched for this but did not find a thread that applied. I figured it out after inspecting the antenna carefully. No fancy tools needed. Antenna has a 2 straight parallel edges near the bottom which allow you to use a small crescent wrench to remove it. Simply turn the antenna counterclockwise to remove. Thread back on by hand and slightly tighten with the wrench. Do not overtighten. I recommend you remove it when taking it to any car wash that uses machines/brushes that spin. You risk having it broken off, otherwise. Do not forget to turn the mirrors inward also.
  2. Nov 4, 2017 at 1:06 PM
    Danny9505
    Danny9505 New Member
    Danny
    2013 Tacoma SR5
    4x4 tricked out
    I had to do this today. The bottom part of the sheared off bolt is usually somewhat loose. Use a small regular drill bit and center it as best as possible. Drill a hole in the old stud about 1/32. Use a small star bit slightly larger than your hole and tap it in until snug. Then just unscrew the lower section of the sheared of bolt. Simple but it works!
  3. Nov 4, 2017 at 1:26 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Thanks
