How To Remove Blanks From Center Console?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jackrules, Aug 23, 2011.
  1. Aug 23, 2011 at 1:39 PM
    jackrules
    jackrules [OP] Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    hey, I want to remove those blanks to do the USB modd for my iPhone, but I don't see how to get the blanks out.
    Can someone tell me where to push / pinch / pull to remove trim so I can get those things out?
    Thanks
  2. Aug 23, 2011 at 1:48 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
  3. Aug 23, 2011 at 3:31 PM
    rhavin42
    rhavin42 Well-Known Member
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    screwdriver, they just pop out.
    You might nick them a bit, but once you put them back in you cant even tell.
  4. Aug 23, 2011 at 4:33 PM
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    Not familiar with the USB mob but are you going to dispose of the blanks when you install the mod? The reason I ask as I'm looking for a set of the under console blanks in good condition so if you want to sell them you potentially have a buyer.
    Now, how to get them out the best way I found is using a thin strip of metal that you place as a brace along the base of the blank and then carefully prying a wide, flat and thin screwdriver under the edge. The metal piece is to avoid damaging the surrounding plastic.
    Overall the easiest way of removing them without damaging them is going in from the back but with the center console that is impossible unless you take off the surrounding plastic. The easiest way of removing them with damaging them is to use a drill and put a hole in the middle, then just use a sturdy wire hook to pull them out.
    PM me if you are interested.
  5. Aug 23, 2011 at 4:35 PM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    Take your coin tray out. Then stick your finger up there and pop it out from behind.
  6. Aug 23, 2011 at 5:02 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    This is what I did this weekend on the center console. Just gently pry from the bottom with a flathead screwdriver.
    Even if you take out the center console and everything you can't get to the back of the blanks. Be gentle with the screwdriver and you'll be fine
  7. Aug 23, 2011 at 11:36 PM
    jackrules
    Jack
    San Diego
    I will be using the blank I remove.
    Thanks for the imput guys! Lots of help on a subject that I couldn't find much info on...
