How to remove cover?
Discussion in 'Towing' started by cspcrx, Sep 16, 2009.
  1. Sep 16, 2009 at 12:05 PM
    cspcrx
    cspcrx [OP] Well-Known Member
    21 TRD Sport 4x4 Cement
    Ok I just got my Protege controller from Etrailers. Wife does not want any holes drilled in the truck and doesnt want the controller mounted on the bottom of the dash since it hits her legs. I was looking at mounting it inside the compartment infront of the shifter below the power outlets and aux input. My question is how do you remove the black covers that cover the extra holes for switches? My thought was to run the wire through the hole, so I dont have to drill a hole but I must be missing something on getting the black cover off. Thank you.
    Also if anyone has pics of theirs mounted there could you post it please?
  2. Sep 16, 2009 at 1:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Not sure if this helps:
  3. Sep 16, 2009 at 6:10 PM
    cspcrx
    Thank you. I dont see the covers pictured. I am sure they just pop out but i am affraid to damage them or the panels.
  4. Sep 16, 2009 at 6:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    My blanks pushed out from the rear, IIRC.
  5. Sep 16, 2009 at 7:52 PM
    cspcrx
    Ok that helps. I will try that. Thank you.
