TPMS light weirdness
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mookinator, Dec 5, 2018.
  1. Dec 5, 2018 at 7:34 AM
    Mookinator
    Mookinator [OP] Member
    2017 TuRD Sport ACLB 6MT
    So since it's getting cold tire pressures are dropping. This morning I came out to my truck and was greeted with that familiar yellow light. What I don't understand is WHY IS THE LIGHT ON? The FEDERALLY REQUIRED door jam sticker on my truck says the recommended tire pressure is 29PSI. Why is the light telling me that the tires are correct? Shouldn't it tell me when they are LOW? And why is 29 too low for 3 tires but not the 4th?
    I normally run the tires at 32psi cold and inflating them back up isn't a problem. I'm just curious
  2. Dec 5, 2018 at 7:44 AM
    TXtacoTRDOR
    TXtacoTRDOR Member
    McKinney, Tx
    2018 White Tacoma TRD Offroad
    I have been having this same problem usually with just one tire.
  3. Dec 5, 2018 at 7:50 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    I’m nearly certain the system alerts you when there is a big change in pressure. So if you were running say 39 pounds then it dropped to 29, you lost 10 pounds so it’ll alert you.
  4. Dec 5, 2018 at 7:55 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Any idea what the TPMS pressure was set at for PSI? I'm in a 2nd gen and have a button where I can reset the PSI to whatever I want based on the current tire pressure, not sure how that works on a 3rd Gen.
    I tried to find out what percentage below the light would come on, but can't find anything.
    The three tires that are illuminated could be as low as 28.5 while the one that isn't illuminated could be as high as 29.4 (all round to 29). I'm betting the system sees the decimals, but the screen doesn't.
    Tac0Tic0 likes this.
  5. Dec 5, 2018 at 8:05 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    It all depends on where the system pressure was set last. Bring them up to around 32 cold and see if it clears.
    Had an oil change done at Walmart on my 2nd gen a few years ago and they put the pressure down to the door sticker value and lit up my TPMS system. I was running after market tires at 36.
    G.
  6. Dec 5, 2018 at 8:11 AM
    YF_Ryan
    Kent, WA
    And don't be surprised if the tires are mixed up vs the screen. I kept filling up one of the tires on my wife's car using the screen as the gauge... I started wondering if the screen had a big delay until I noticed a different tire than expected was now over inflated by 15 pounds :)
    daveometrod likes this.
  7. Dec 5, 2018 at 3:18 PM
    RabidRotty
    RabidRotty Active Member
    That happened to me a month ago, just add 2 psi each tire restart your truck and drive it a couple of blocks. It will reset and all is good
  8. Dec 5, 2018 at 3:33 PM
    Methadras
    Methadras Well-Known Member
    South DFW, TX
    2021 White TRD Sport 2WD
    Fox 2.0 Lift, JLA Uppers, Dual battery setup, ARB-Double Barrel compressor, CBI skidplates, CBI Covert bumper, Winch, various light setups.
    I don't know. Maybe try putting in the to see if it goes away.
  9. Dec 5, 2018 at 3:42 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think a 10 percent drop is what triggers the light.
  10. Dec 5, 2018 at 3:44 PM
    Victory
    Victory Well-Known Member
    St. Pete, FL
    2016 White Tacoma TRD Off Road
    There is a reset button under the dash. If the button was pushed when the tire psi was high it could trigger the light to come on even though the psi is still okay. I can’t remember what the manual said the pressure drop was to trigger the light, 5 or 10 psi lower than when the light was reset and the light comes on
  11. Dec 5, 2018 at 4:01 PM
    STPJ07
    STPJ07 Well-Known Member
    Florida
    2017 OR TRD 4x4
    The TPMS learns what you normally keep your tire pressures at. It stores that info inside the tpms computer and sets a “threshold” accordingly.
    If the TPMS system senses a significant tire pressure drop and hits the threshold # it will trigger the warning light.
    I pulled the following info from Toyota’s FAQ site:
    To reset the system, first make sure the tire pressures are correct.
    Turn the engine on, then press and hold the reset button. Hold the button down until the TPMS indicator light in the instrument panel blinks slowly 3 three times.
    Wait for several minutes with the engine running, to allow the system to record each tire's pressure, then turn the engine off.
