How to remove drop in bedliner, over the rails type
Discussion in '1st Gen. Tacomas (1995-2004)' started by mmiller2002, Dec 15, 2011.
  1. Dec 15, 2011 at 8:25 AM
    mmiller2002
    mmiller2002 [OP] Member
    Fort Worth, TX
    2004 Double Cab 2wd
    I just got this 2004 Double Cab and I want to remove the bedliner to clean out underneath. It says "Classic Liner" on the front by the cab. It goes over the rails and over the front top of the bed.
    There's 4 screws that have loose triangle shaped wedges that clamp under the bed rails. I can get at the rear 2 because of the holes in the loner for the cargo hooks, but the front ones are blind. For the front should I just remove the wedges and let them fall behind then flex the liner out? If so, how do I reinstall the front wedges without scratching things up?
    Thanks,
  2. Dec 15, 2011 at 8:34 AM
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    not quite sure about yours, but my old bed liner has rectangular peices that looked like they were part of the liner, but in fact popped up. I just needed to pry the bottom out a bit with a regular screw driver.
    Maybe some pictures would help.
  3. Dec 15, 2011 at 12:15 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    There are screws that you can see, loosen those screws, and that will twist those triangle pieces out of the way of the lip of the bed rails. THen just jiggle is a bit to lossen it up and pull that crap out.
    Better yet, just unscrew those 4 bolts all the way out. The triangle pieces will fall into the bed, but it'll free everything up. Then just pull that piece of crap out, clean the bed, and get a spray-in or DIY bed liner. I just did a Hurculiner last weekend...
  4. Dec 15, 2011 at 9:28 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    This ^^. (Did it before I had my Rhino installed.)
  5. Dec 16, 2011 at 5:33 AM
    mmiller2002
    Fort Worth, TX
    2004 Double Cab 2wd
    Thanks all.
    So let's say I get it out, clean up, and maybe coat the bed. If I want to reinstall it, how does it go back in with those triangles installed up front? Is it just a bend and force kind of thing? Or, is there a more elegant way to get it installed?
    Thanks again,
  6. Dec 16, 2011 at 4:45 PM
    Ohbrian
    Ohbrian Taco Roja
    Brian
    Fremont, CA
    04 PreRunner
    Eclipse head unit,scratched paint,ripped seat, black chaos 6 rims, Bilstein 5100's, top plate spacers, AAL, Midget antenna, Bakflip G2 cover, 14" Magnaflow, 400W inverter, LR UCA's
    I just pulled out my Toyota liner from my dcsb, and I'm convinced this piece of shit does more damage to the bed than it stops. Many spots worn down to bare metal. I hit it with some primer on the bare spots, I think I'm going to try to spray some type of liner in myself.
  7. Dec 16, 2011 at 9:13 PM
    Norton
    Yep.
    IIRC, you loosely "pre-install" the triangles, then put the liner back in-place, after which you simply tighten the screws. As they tighten, the triangles rotate into place and secure the liner.
