How to remove factory clamp 2013 tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rysterpanther20, Mar 11, 2014.
  1. Mar 11, 2014 at 5:20 PM
    rysterpanther20
    rysterpanther20 [OP] New Member
    Tucson
    2013 Tacoma 4x4 SR5
    I'm trying to install my icon add a leaf to my truck, was just wondering how everyone else removed their factory rear clamp so that the i can put the add on leafs. in the instructions this is what it reads :
    Pending the year of your vehicle our add a leaf pack may overlap the rear factory spring pack clamp.If this is the case you will need to remove the factory spring pack clamp at this time.
    Also, is it better to leave in the overload spring or remove it? I do have the 2.0 aluminum resi shocks.
    Any input would be great thank you!
  2. Mar 11, 2014 at 6:58 PM
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    From what I have seen on the forum you have to cut off one of the spring clamps and then grind it smooth before install of the AAL.
  3. Mar 11, 2014 at 7:58 PM
    discoy2k
    discoy2k Well-Known Member
    DISCO
    NOLA
    05 TRDSport 3" Iron Man Coil, Stealth
    2005 to 2012 Front End Replace,2010 TRD Interior,6x Escort Shifters, Escort 9500ix, Escort LIVE w/ 4G Data, 100% Stealth on Interstate,De-Badged Completely,5% Tint Blacked out,Iron Man lift,InfraRed military Humvee Spots, Drive in 0lite,Lexus/Fujisu NAV, dual 8in lcd sun visors, 2 10" kicker solobaric dvc 2ohm, phoenix gold 2000 watt, lunar 100watt @ 1/4 ohm,3 farad cap kicker 250watt,2800watt ,TRU-SINE inverter, dual HID bulb+HID fogs w/ mod, Roof rack,Westin Bull Bar, Manik Side Bars, Sirius/XM (HACKED) Undercover Bed Cover, bosch Wipers, Iridium Plugs, Undercover Bed Cover
    you mean the clamps that keep the spring pack together? i have not done the add a leaf to mine yet but on my other trucks the add-a-leaf was much shorter than the other leafs and you didnt take the assembly apart you add the leaf to the bottom, clamp the springs, you remove the u bolts, then put the add-a-leaf at the bottom with new center pin and lower the truck and replace u bolts.
    its been several years, but i dont remember unpacking the oem leafs?
    cheers.
    disco
  4. Mar 11, 2014 at 8:08 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    if you have the 3 leaf back you don't have to cut the clamp only with the 4 leaf pack.
