How to remove factory fog lights?
Discussion in 'Lighting' started by 06Bluez, Feb 22, 2010.
  1. Feb 22, 2010 at 11:49 AM
    06Bluez
    06Bluez [OP] Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    I have condensation in my factory fog lights. I need to remove them so I can dry it up and re seal. I cant find any instructions and can't quite figure it out myself. Anyone know how to remove the factory fogs on a 2nd gen Tacoma?
  2. Feb 22, 2010 at 12:36 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Help me CHRIS4x4!!!!
  3. Feb 22, 2010 at 5:35 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    Remove the grille for easier access (headlights if you want to, too). They pop right out, there are retainers on both the right side and left side of the foglight. Do not touch the adjustment knob.
  4. Feb 22, 2010 at 5:38 PM
    808matt
    808matt Well-Known Member
    hawaii
    15 crew cab
    grill or bumper?? you should be able to pop the fog lights out. just stick your head under and you'll be able to see how they are connected
  5. Feb 22, 2010 at 6:32 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    just reach up from under the bumper and they will pop right out. push from the back of the light, there are little clips on the bumper that hold them in, pull those out and push, it'll come right out the front.
  6. Feb 22, 2010 at 9:56 PM
    Viet2100
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    Haha the method you guys are describing is too vague. Removing the grille (headlights too if you want) will give you a better view and easier to reach. No need to remove the bumper.
  7. Feb 23, 2010 at 11:23 AM
    06Bluez
    Phoenix, Arizona
    06 4x4
    From underneath I cant see any clips. Maybe ill try and take the grill out so I can see better from the top.
  8. Feb 23, 2010 at 2:20 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    go stick your head under the bumper where you are looking at the foglight from the rear...its not a clip really, its a piece of the bumper that when you push the light in from the front it just snaps in. once you figure it out your gonna smack yourself on the forehead. I've had mine out so much that i can do it just by sticking my arm up in the bumper.
  9. Feb 23, 2010 at 5:21 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Thanks Ill try first thing when I get home.
  10. Feb 24, 2010 at 8:58 AM
    06Bluez
    Phoenix, Arizona
    06 4x4
    No luck last night.
    Are the clips 2 circle things on each side of the light that must be pushed on? because I can get one loose but the other wont budge.
  11. Feb 24, 2010 at 9:15 AM
    bcsnave
    bcsnave Well-Known Member
    Wisconsin
    06 4x4
    unclip the one side..then try and turn it a little bit..they will come right out of the front
  12. Feb 24, 2010 at 9:24 AM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Once I have 1 pushed in the other one wont budge. I dont know how anyone could do this with there fingers. Im pushing with a screwdriver and it still not budging.
    Has anyone done this without removing anything (grill, bumper, headlights?)
    This is a PITA out of all the mods ive done this is by far the hardest!!! I cant get these freakin lights out.
  13. Feb 24, 2010 at 2:43 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    yea, unclip the one side and push, it should twist a little and come out
  14. Feb 24, 2010 at 3:32 PM
    Viet2100
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    Use a small flat head to pry it out.
  15. Feb 25, 2010 at 8:56 AM
    06Bluez
    Phoenix, Arizona
    06 4x4
    I did all that ^^^. Ill try again tonight.
  16. Aug 29, 2012 at 12:23 PM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    Bluez,
    I'm assuming you were eventually able to remove the fog lights from the bumper...
    How did you remove the condensation? Any tips?
  17. Aug 29, 2012 at 12:34 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    The fog lights do not come apart like the headlights. You can dry them out by pulling the bulb and letting the moisture naturally dry out. The problem is, you could end up with water spots that would be slightly difficult to remove (can be done with a little patience and maybe some jetdry). You then need to figure out why they leaked in the first place and seal them up with some silicone sealant.
  18. Aug 29, 2012 at 12:40 PM
    619Tacoma
    Call me Rocco
    San Diego, CA
    Thanks Pugga. I should have addressed the moisture issue long before but just put it off until now. I currently don't have any condensation (not anymore) in the housing but because of the water that got in there a while back and dried out, it has a dirty yellowish color to the lens.
    Since they don't come apart like the headlights, I'm thinking of buying one of those brushes that are used for washing baby's bottles & such with the foam on the end to scrub the inside of the lens through the hole where the bulb goes in. Thinking of simply using soapy water... Any other product I should use instead?
  19. Aug 29, 2012 at 2:10 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    I would just remove the bulbs and blow compressed air into the housing.
  20. Aug 29, 2012 at 2:38 PM
    Pugga
    Massachusetts
    F-150 Mod
    Soapy water will work. Jet dry helps dry spots on the inside so you can get a clear lens when you're done. Just be careful not to use anything that will eat at the chrome reflective surface. It's very soft and comes off easy. Here's a thread if you decide to get ambitious and tear into the lights. It can be done, it's just not overly simple to do.
    http://www.tacomaworld.com/forum/lighting/187831-fog-light-retrofit.html
