How to remove fluid film
Discussion in 'Detailing' started by rhowell, Oct 14, 2014.
  1. Oct 14, 2014 at 10:14 AM
    rhowell
    rhowell [OP] Well-Known Member
    Robert
    Canada
    08 Indigo TRD Sport 4x4 DCSB
    -Leather with Heated seats -AFE cold Air Intake -DE-jr Rims -Upper and Lower grills from Black Diamond Fabrication -Light bar behind grill -Hella Black Magic Rallye 1000 lights. -OME lift cw Dakar leafs -LR Upper control arms -Rosen duel DVD headrests -Nfab steps -leer canopy
    Good day all,
    Just went under my '08 and there is no rust except on the welds for the rear struts and up front on (the triangle mounty thingies with the round hole in them). I scraped off the rust and applied fluid film for this winter.
    When spring comes I am thinking I would like to really sand down these locations and apply a rust converter and spray paint. Then continue with the seasonal fluid film treatments.
    How do you prep a fluid film treated frame to paint it.
    Thanks.
  2. Oct 14, 2014 at 10:16 AM
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    this is from the Fluid Film website:
    How do I remove FLUID FILM so that I can paint an area, and then reapply?
    For equipment that is to be painted following a treatment of Fluid Film, a more vigorous cleaning is advised. A high-pressure, hot water or steam detergent wash (minimum 120F) is needed. Utilizing cleaning compounds specifically formulated to remove grease/wax as a pre-treatment process for painting are highly recommended.
  3. Oct 14, 2014 at 10:18 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Good idea. Fluid film is not a good primary coating for steel unless you like routine maintenance.
    Good secondary coating for sure.
  4. Oct 14, 2014 at 10:26 AM
    rhowell
    Robert
    Canada
    Thanks for the quick response.
  5. Oct 14, 2014 at 10:30 AM
    eviele
    eviele Well-Known Member
    What is a good primary coating if you don't mind me asking?
    I have a little surface rust too that I'd like to take care of before adding fluid film and don't know what rust converter or paint folks recommend.
  6. Oct 14, 2014 at 10:32 AM
    Shauncho
    Shaun
    Parts Unknown...
    none
    a well prepped surface with lots of paint is key...
    ...nothing is forever. Living in that kind of climate you're pretty much always going to have to keep up on the maintenance.
  7. Oct 14, 2014 at 10:34 AM
    XXXX
    sKiP
    05 Prius
    Only time will tell. I did every piece of frame I could not sand down to bare metal with Rustoleum rust converter that comes in a bottle and you brush on. I then primed, coated with bedliner, and finally top coated with gloss.
    If it makes it more than a season Ill recommend it to others because nothing else has held up including Sherwin Williams HD Chem bond and some other industrial type paints Ive used.
  8. Oct 14, 2014 at 12:08 PM
    eviele
    Thanks.
    I ran out and got some of the rustoleum that you mentioned and will give it a shot as well.
    Good luck OP, sorry for the hijack.
  9. Oct 14, 2014 at 12:27 PM
    XXXX
    sKiP
    05 Prius
    Follow the directions.... you can't top coat with any spray paint for at least 3 days. This waiting period made this a much longer job than I had anticipated so I figured I would let you know of this long dry time now.
