How to Remove Hub Dust Caps?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JGJ, Jun 1, 2011.
  1. Jun 1, 2011 at 8:14 AM
    JGJ
    JGJ [OP] Well-Known Member
    I'm in the middle of changing out my CV axle. I'm having trouble getting the hub dust caps off. I dont want to damage them. They're on pretty good - got 90K miles on the truck.
    Any ideas / help on how to get them off? I'f trying the flathead screwdriver method but not having any luck.
    Thanks
  2. Jun 1, 2011 at 8:17 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Tiny flat head screwdriver and a hammer. Just keep hitting the screwdriver with the hammer and it'll eventually work its way between the cover and the hub. Once it starts, use a larger screwdriver and pry. Work your way around like that until the thing pops off.
    10trdtaco likes this.
  3. Jun 1, 2011 at 8:20 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    ^ Yep x2 i have a old screw driver just for these type of things I hit it with a table grinder to thin out the tip some more and it works wonders to these type of things.
    Gunshot-6A likes this.
  4. Jun 1, 2011 at 9:02 AM
    JGJ
    got it. thanks guys.
  5. Jul 7, 2016 at 8:14 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Anyone have a part number for the hub grease cap? I'm having the hardest time finding it on a parts diagram (and in search). :annoyed:
  6. Jul 8, 2016 at 4:16 PM
    redmike34
    redmike34 Member
    NoVA
    08 TRD Offroad
  7. Jul 8, 2016 at 9:58 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  8. Jul 9, 2016 at 11:08 AM
    DEMikey
    DEMikey Mr. Badwrench
    mikey
    delaware
    2013 red taco
    100XR, OTW Surf Rod Rack, Toytec 3" lift, +1 on tires
    if you are doing cv's yeah you dont have a choice. but doing the ecgb you dont need to mess with it. first one i did i did it that way. last one i did, i took the spindle off with it.
    just thought id add that.
  9. Sep 24, 2016 at 11:03 AM
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    I hate to bump an old thread, but I can't get mine back on! I've been at it 45 minutes trying to get that stupid little hunk of garbage on there. This in essence should be the simplest part of this whole process. Any tips/tricks?
    TreeFortRichard likes this.
  10. Sep 24, 2016 at 11:13 AM
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
    I applied a small amount of bearing grease on the lip of the dust cap. Once I got the dust cap hammered on, wiped away any excess grease that came out.
  11. Sep 24, 2016 at 11:33 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Rubber mallet.
  12. Sep 26, 2016 at 6:39 AM
    Mark
    Covington, LA
    I finally got them on after about an hour trying with one. The second one only took about 45 minutes. It looks like they went through a hail storm, but at least they are on.
  13. Jul 1, 2017 at 6:02 AM
    owen06
    owen06 Well-Known Member
    Hinesville, GA
    16 DCSB 4x4 Red
    Old thread again.. I know.. but I put a tiny screwdriver hole in my dust can't get trying to remove it. Can I patch it with something or should I get a new one?
  14. Jul 1, 2017 at 3:18 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Get a new one...
