HOW TO: Remove/Install a starter/fix a clicking starter (2.7 liter 3RZ-FE engine)
Discussion in '1st Gen. Tacomas (1995-2004)' started by trdracing5, Sep 17, 2011.
  1. Jan 12, 2019 at 7:14 PM
    #61
    aeok18109
    aeok18109 Well-Known Member
    Ernesto
    1996 Blue Tacoma 4wd 2.7L 5sp
    The rubber liner in the wheel wells hiding the engine from view? Yea you can yeet those fuckers into the sun without issue.
  2. Aug 16, 2019 at 12:32 PM
    #62
    AJ1G
    AJ1G Active Member
    Stonington, CT
    2012 2.7L Auto 4X4 SR5 Access Cab
    This was a very useful post, just got done changing out the starter on our 2012 Tacoma extended cab 4x4 with the 2.7 liter 4 banger. At just over 78k miles and over 7 years this was the first major repair needed on it, other than replacing a headlight bulb and a license plate bulb!
    Starting had gotten sketchy and I had eliminated a battery problem with a load tester from Harbor Freight. All wiring checked out, only unusual observation was a measured 10mV voltage drop between the battery negative post and the ground connection on the fender wall at 30 amps of running load with the heater blower on high speed (at 15 amps half of the total load at idle with lights on and high beams on). Extrapolating our to worst case voltage drop at 750 cold cranking amps peak, voltage drop at that condition across the small cable jumper between the battery and the fender wall would only be 0.25 volts peak, probably not significant. Cleaning the battery connection and the connection at the firewall did not change the measures voltage drop, I suspect it’s occurring at the crimped connection between the cable and the spade flat at the fender end of the short negative battery lead, may eventually install a new one.
    Total time to swap out the starter was about 2.5 hours, 90% of which spent loosening and subsequently tightening the upper starter mounting bolt. Every job always has that one f& bolt that gives you fits!
    I decided to do this job myself because the post led me to believe everything could be done through the wheel well and not from under the vehicle. Not so, needed to spend considerable time on my back looking up and getting a grip on the f& upper mounting bolt to loosen and tighten it. Broke it loose with a 14 mm offset combination wrench, once it was broken free, ended up mostly using my fingers to loosen it and tighten it the rest of the way. What may have helped was a 14 mm socket with some non-skid tape wrapped around it to allow my fingers to get a better grip. A stubby 1/4 inch drive ratchet and a short 14 mm socket would likely have had to enough room to work, standard size 3/8 ratchet did not have any significant room to swing.
    I hate having to lay under a car on my back because over the last few years it almost instantly makes me nauseous, apparently a vertigo related thing when you are lying down and you are looking up at items only inches away. Have found it’s not uncommon. My indie mechanic says same thing happens to him when he has to work upside down under a dashboard. Once the nausea sets in, it takes a while to go away.
    Chris B
    Stonington, CT
    cruiserguy likes this.
  3. Aug 16, 2019 at 1:35 PM
    #63
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Save the original starter (very high quality Denso unit) and disassemble the solenoid and replace the contacts and plunger, it's not hard or time consuming, I promise. Parts are under 20 bucks and now you have a higher quality rebuilt Denso unit, better than anything out there, besides new Toyota OEM
  4. Aug 16, 2019 at 1:51 PM
    #64
    AJ1G
    AJ1G Active Member
    Stonington, CT
    Thanks for the tip, will consider it. Will cost me my 40 buck core deposit at AZ, but in the long run, might have a relatively inexpensive backup unit. Does the rebuild kit include new commutator brushes?
    Curious as to how the solenoid contacts look. Predictably, the truck has always started normally in the last few days since I bought the replacement starter!
  5. Aug 16, 2019 at 3:56 PM
    #65
    cruiserguy
    Elijah
    SEKS
    Just the typical contacts and plunger are in the rebuild kit.
    At least part stores honor the lifetime warranty on the crap parts. People get real good and quick swapping in a new aftermarket starter every year or two:rofl:
    Just keep the receipt in the glove box, for when you need it:D
  6. Sep 30, 2019 at 4:29 PM
    #66
    crawdad
    crawdad Member
    Bruce
    Louisiana
    07 PreRunner
    Read your helpful instructions and thank you.
    I just wanted to add that in my son's truck's case, it was much easier to remove and replace the starter. He has a 2WD 2.7 L engine and he removed the starter without removing the wheel or anything more than the wires and the 2 bolts, not that it was easy. Just wanted to report that this was possible because our research indicated that the job would be much more involved than it was.
  7. Apr 27, 2020 at 3:22 PM
    #67
    slimvest
    slimvest Member
    '00 Tacoma 5-lug
    Another satisfied customer of this thread. Thanks for sharing this info.
    2000 2.4 2WD. I did the wheel off, starter pulled through the wheel well method. Glad I had a 14mm ratcheting box wrench for that top starter bolt. One interesting thing I noted, the larger of the two brushes was significantly more worn than the other. Truck has 76K miles on it.
  8. Aug 28, 2020 at 2:39 PM
    #68
    townace
    townace Member
    CA
    2nd Gen 4WD 2.7L AC
    1997 2.7l 4WD. I was able to get the starter out through the wheel well. Didn't think I would be able to at first. Removed the bolt holding brake line to the frame, moved brake line coil from above under hood slightly. Took the starter out oriented just like the picture in the original post. Went back in by just reversing the way it came out, was even easier on the way in. Thanks
  9. Sep 8, 2020 at 4:51 PM
    #69
    rickyg2008
    rickyg2008 Well-Known Member
    On their website is it just the plunger and 2 contacts needed for the rebuild ?
    Old post
    Is this the kit people have been buying
  10. Sep 8, 2020 at 4:57 PM
    #70
    rickyg2008
    Does that kit come with the screws
  11. Aug 29, 2022 at 11:51 AM
    #71
    skycamper
    skycamper Well-Known Member
    Abraham
    2001 Tacoma 4x4 2.7L Ext Cab
    3" Lift w/ 5100's and EMU 882 springs , General Leaf Spring and AAL in rear with 5100. Diff drop, carrier drop, 3 degee axle shims. Trail Gear Tube Bumper. Tundra brake mod.
    Just ordered mine! My truck did the loud click after sitting 5 weeks! Battery dead, charged to full and only got a loud click....after a couple tries it started. 2001 2.7L with 189k.
  12. Aug 29, 2022 at 1:55 PM
    #72
    MaxTorque
    MaxTorque Hope is not a strategy...
    Maryland
    cup holders
    Great post with the pictures. With many makes and models of vehicles, the dreaded multiple "click" before the starter finally turns over is 90% of the time worn copper contacts in the starter. Thanks for the parts source.
  13. Oct 16, 2024 at 7:08 PM
    #73
    sgtlethargic
    sgtlethargic Well-Known Member
    This is my second time using this tech write-up. Both times I bought a universal Dorman kit #02349 and only changed the copper contacts. The kit was $32 and has all of the pieces that mount to the contacts, but no plunger. The plunger isn't needed. I only changed the crescent-shaped contact this time because the other one wasn't worn. The crescent one was worn about an eighth of an inch across and a sixteenth deep. The starter and solenoid tested good at Autozone, but took a few clicks to start in the past day. With the one contact changed, the starter has a lot more oomph, like going from a weak battery to a good battery. So, if your starter's not turning over strong, it could be the contact(s). The other (previous) starter went suddenly. This one went in a day, but I might've been able to get by a little longer. Rock Auto or a local rebuilder (if any are left) probably would've been cheaper for parts, but ...
