How to remove lower ball joints
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jerris, Jan 23, 2010.
  1. Sep 9, 2012 at 6:55 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    And moog is great.
  2. Sep 11, 2012 at 12:14 PM
    goufcustom
    goufcustom 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    Yeah, I have Moog all around on my Miata, those were easy. I think I am going to attempt this, I have a spare set of lower arms, and it seems worth while, and the Moog ball joints are only ~$25 each from Rock Auto. I have access to a 12 ton press, so that should help too.
  3. Sep 11, 2012 at 12:45 PM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    did you use a press kit? you can rent them for free at auto zone
  4. Sep 21, 2012 at 9:59 AM
    spazjensen
    spazjensen Well-Known Member
    Here
    06 Tacoma Prerunner SR5 4cyl 5spd Manual
    3" lift with Biltein 5100's w/Eibach Coils, SPC UCAs
    I have a very loud popping and clanking noise when i'm turning. pretty sure its my lower driver side ball joint. I'v never replaced a ball joint but if it can be done without buying the full lower control arm i will. All of you talked about having to beat the hell outta the thing and modifying tools and all. but has anyone used the ball joint press that was mentioned? also if there's a thread that gives a good step by step i'd appreciate it.
  5. Sep 21, 2012 at 12:09 PM
    goufcustom
    MD
    I think the process is simply to remove the clip on the top side of the arm that "holds" the ball joint in. Then be creative about pressing the ball joint out of the arm. Then reverse the process after cleaning the control arm and install. In theory it shouldnt be too bad, I havent done it, but I have looked at it and done other ball joints on other vehicles like this.
    I have a spare set of LCAs that I have been thinking about doing this to, refurbing them, and either selling them or using them after I put some more miles on my truck.
    Where are you located?
  6. Sep 21, 2012 at 2:41 PM
    BamaToy1997
    Bill
    Navarre, FL
    Moog makes the best aftermarket ball joints and tie rods. The nipples are always difficult because the hole that you put it into is not threaded. When you put the nipple in yourself, it threads the opening. Saves them money on assembly since they can just put the nipple in the bag and let US install them. lol.
    As for removing the joint from the spindle/knuckle, I have never had any trouble using a single 5 pound hammer on the edge of the knuckle as was described in the "two-hammer" method. No need for two hammers, but that is my opinion. You just have to be careful. I WOULD suggest that you do NOT hit the castle nut to try and knock it loose. While it is not always the case, when you strike that nut, you can distend the threads and ruin the nut without realizing it.
  7. Sep 21, 2012 at 3:04 PM
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    ok guys I just saw this thread on the home page. I have replaced my ball joints yesterday. Moogs on the lca's and stocks on the uca's. I have a mattco super set ball joint tool. It was very easy to remove and install uca ball joints no problem. Lca ball joints expecially the moogs take a rediculous amount of pressure to push in. With that being said take those lca's to a shop or anywhere you know has a shop press. ie. military base hobby shops etc and press them in with the shop press. So easy that way. It was past 10 tons of pressure before it fully seated. I tried to put a moog lower ball joint in with the tool, and my tired girlfriend, my tired bench vise sore arm and broken craftsmen wrench with cheater pipe i still had between a 16th and 1/8 to go. lol press them in call it a day, easy.
    blakebarnes and MotoEd like this.
  8. Sep 24, 2012 at 6:41 AM
    spazjensen
    Here
    thanks ya'll. I think I will get the MOOG joints and take it to a shop here in town thats pretty good when it comes to 4x4's and such. I cant drop the money for a set of LCA's. But one more question:
    Will the MOOG joints work fine with a taco that's lifted 3"? I'm saying that the lift caused my lower ball joints to give out.
  9. Sep 24, 2012 at 8:21 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    The lowers should be fine, it's the uppers that get greatly affected by a lift.
  10. Sep 24, 2012 at 9:36 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    There is a write up that includes changing out the LCA bushings, i'm not on my comp so i dont' have the link. You pretty much need a press, and a propane torch too heat up the metal around the ball joint just a lil bit to expand and press out.
  11. Sep 25, 2012 at 1:03 PM
    Rooster Feather
    Rooster Feather Member
    Oklahoma
    2007 V6 SR5 4x4
    I replaced my lower ball joints and ruined one of the "C-Clamp" presses from O'Rilley's. I replaced it them with Moog. Hopefully I don't have to do that again! I have the needle bearing to bushing job to do and have been completely dreading it. I came back to the forum to browse around and saw a picture of the LCA. I was delighted to see that it BOLTS to the spindle! (I had forgotten that) I sure hope that the lifetime warranty on the Moog balljoints make the balljoints last a lifetime! I don't want to do that again. I didn't realize that many purchase LCA with the balljoints already in them. After I got the first side done, I would have probably gone for that! I think I used and bent every tool that I had trying to get the old out and the new in! I used a lot of the caveman technique. If it doesn't move, use bigger hammer!!! Would be embarrassed to include pictures of the way I did it.
    Craig
  12. Sep 26, 2012 at 3:44 PM
    jmarquez808
    Jess
    Hawaii
    Ha ha trust me man without a shop press.i feel your pain i stripped the mattco tool and broke my wrench, almost tipped a table over with the vise on ot then i decided to go use a shop press lol.
  13. Jan 29, 2015 at 6:48 PM
    PANCHOMEX
    PANCHOMEX New Member
    sonora mexico
    06 PreRunner sr5
    I'VE TRIED TO CHANGED AN IT WAS DIFFICULT, I just take off one the left lower ball, and put it back the same, because i wasnt sure, because , I use heat (torch) to remove it and to put it back, so it was very easy whith the heating method. but i'm not sure if it is the rigth way
  14. Jan 29, 2015 at 7:10 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    I'm wondering the same thing.
  15. Mar 12, 2017 at 3:20 PM
    #35
    Camels20
    Camels20 Active Member
    Dave
    2009 Tacoma TRD
    But have you actually done it with a pitman arm separator before?
  16. Mar 12, 2017 at 5:43 PM
    #36
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Have one sitting in my toolbox that I use on every single ball joint that needs to be separated.
  17. Jun 2, 2017 at 5:27 AM
    #37
    chinorx3
    chinorx3 Well-Known Member
    Florida
    06 Tacoma Lifted
    Pro Mod Lift Kit , Method wheels on 35's
    :frusty:Going to be doing this in the very near future
    BandanaBerg likes this.
  18. Oct 3, 2017 at 2:26 PM
    #38
    BandanaBerg
    BandanaBerg Yotas Yotas Yotas Pocast
    Phoenix,AZ
    2010 DCLB SR5 4x4
    Up Front; Icon 2.5 Extended w/ Fox 600s, Icon Delta Joint UCAs, Poly Performance Taco Tabs, BAMF Hybrid Bumper, Pelfreybilt Legacy IFS Steel Skid, RCI Transfer Case Skid Out Back: Archive Garage Hammer Hangers w/ High Clearance Cross Bar, OME Dakar Expedition Pack, Icon 2.0 RR, All Pro U-Bolt Flip w/ Super Bumps, All Pro Extended Brake Lines, Trail Gear Rock Assault Bumper w Custom Swing Tire Carrier Wheels & Tires: Pro Comp 5001 Wheels 16" on some 285/75/16 BFG AT KO2, ARB Single Compressor Up Top & Around: RCI 5° Rock Sliders, CaliRaised LED Premium Roof Rack w/ CaliRaised LED Dual Function Light Bar, CaliRaised LED Amber Fogs in CaliRaised LED LED Fog Light Pod Replacement Brackets, Anytime Fog Mod, CaliRaised LED Ditchlight Fogs on CaliRaised LED Low Profile Ditch Light Brackets, Voswitch UV100 Switch Controler, Chineseum Chase Ambers & reverse/camping LEDs Misc Thangs: Tech Deck w Ram Ball Mounts, Expedition Essentials 2nd Gen Rail w/ Ram mounts...
  19. Oct 3, 2017 at 2:27 PM
    #39
    BandanaBerg
    Phoenix,AZ
    2010 DCLB SR5 4x4
    Did you end up doing this?
  20. May 10, 2023 at 4:54 PM
    #40
    DenverSteve
    DenverSteve New Member
    The steering stop bracket was seized onto my lower ball joint on my 2015. A pickle fork wasn't thick enough to pry it free, and a ball joint removal tool kept slipping off. My neighbor helped hold a pickel fork in place and then I placed a second pickle fork in the opposite side and hit it 6 times. It finally let go. Hope this helps...
