How to Remove Mirror Cover on 2013 Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hot Taco, May 1, 2013.
  1. May 1, 2013 at 6:48 PM
    Hot Taco
    Hot Taco [OP] Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks Bilstein Shocks/Struts DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
    ** EDIT: Modified this post from a question to an answer ;) **
    Although my regular cab base model Tacoma doesn't have cool turn-signal mirrors, I want to color match the mirror covers to look like the sport truck mirrors. Note in the photo below, the entire mirror isn't white, just the mirror cover is:
    This lead me to the obvious question: How do I remove the mirror covers?
    Thanks to macgyver for his nice post on "How to: Dis-assembling your mirrors for painting", I was able to figure-out how to get the mirror lens off... pull up from the bottom until it pops-off. Here's the back of the mirror itself so you can see how it hooks on the top and why you must pull from the bottom to get it off:
    However, macgyver's truck is older than 2012 and I don't think his mirrors have covers. While he chose to remove and paint the entire mirror assembly, us 2012/2013 owners don't have to (assuming you want the OEM look.)
    Now that the mirror lens is off, the mystery of how the cover is attached is exposed. I put some red circles around all the points where the mirror cover locks to the mirror itself. To remove the cover, I used a screw driver on the inside to release the tabs while using my finger nails to pry the cap off from the outside so as to not damage anything.
    Here's the naked mirror skeleton:
    And here's the inside of the mirror cover to show the tabs:
    While looking at the mirror lense itself, it's interesting to note that the mirror is slightly transparent. If you had the inclination to do it, adding an LED turn signal kit like the one below probably wouldn't be that hard to do:
  2. May 2, 2013 at 6:59 AM
    Hot Taco
    Richfield, WI
    No one knows? :(
  3. May 2, 2013 at 7:14 AM
    Raz4back
    Raz4back Well-Known Member
    Brett
    Benton, Arkansas
    2012 DC TRD Offroad 4x4
    Blacked out badges, Tinted Tail Lights, Fog Light Anytime Mod, Sock Monkey Bedside Decal, Painted Wheels, 20% Tint on Front Windows, 886 Bulb Backup Light Mod, Plasti Dip Rear Bumper (temporary until I get color matched), Color Matched Grill, Front Emblem, Door Handles, Mirrors, Bilstein 5100 all around, front set at 1.75, 1.5 aal, Crossfab light bar with 3 Hella Black Magic 500s, TRS Retrofit with D2S Projectors and Apollo Shrouds, BHLM with color matched Bowls and shrouds, CSJumper LED interior kit, CSJumper LED switchback DTRLs and Side Markers, 17x9 -12 Offset Ballistic Jester Wheels, 255x75x17 Nitto Trail Grapplers
    I took the mirrors off and seperated the mirror from the cover to paint mine. Theres no way that i know of to remove the cover (except maybe on the limited) without taking the mirror off.
  4. May 2, 2013 at 4:47 PM
    Hot Taco
    Richfield, WI
    Thanks for the reply. That's a bummer. I'm tempted to just start pulling on the cover and see what happens, but I suppose that could get ugly and end-up costing me more than it's worth.
  5. May 2, 2013 at 4:50 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    Other toyotas like the hilux and landcruiser you have to pop out the mirror and you can access the tabs behind it to take off the cover.
  6. May 2, 2013 at 4:54 PM
    Hot Taco
    Richfield, WI
    That's what I was hoping for... I haven't built-up enough couraget to pop-off the mirror yet. I suppose I better try or else I'll forever wonder if the covers can come off or not.
  7. May 2, 2013 at 6:15 PM
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    05 double cab SR5 4x4
    TRD air filter, exhaust tip, tinted windows, upgraded grill, OEM LED tail lights, LED DTRL'S, Matts 123 skid plate, 4Runner Mirrors, 17 inch OEM 4runner wheels
    I have done the 4runner mirror upgrade on my 05 and the newer mirror covers just pop on and you can order all toyota colors from the dealer with or with out turn signals. I'm not sure how hard they are to pop off, the plastic tabs make break easily.
  8. May 2, 2013 at 6:27 PM
    corey.blanco
    corey.blanco Member
    Corey
    Miami, Florida
    13 PreRunner 2.7L 4x2
    plastidipped rims, removed mud flaps, plastidipped grill, debadged, BHLM, tinted taillights and 3rd brake light
    I've been wanting to paint mine too but I'm scared to pull out those mirrors :eek: let us know what you end up doing
  9. May 2, 2013 at 6:31 PM
    Hot Taco
    Richfield, WI
    Unfortunately, only the caps for mirrors with turn signals are available color-matched from Toyota for the 2012/2013 models... leading me to believe that perhaps the cap won't come off. :(
  10. May 2, 2013 at 6:35 PM
    corey.blanco
    corey.blanco Member
    Corey
    Miami, Florida
  11. May 3, 2013 at 12:18 PM
    toyotaman29
    Darrell
    North Carolina
    That's sound right Taco, I used the 2010 4runner limited mirrors with 2012 tacoma covers they fit perfect and color matched perfect, but i have not removed the covers after installing. The older models on tacomas may not remove that way.
  12. May 3, 2013 at 12:30 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    ya know for a small fee (less than these parts cost to replace if you bust 'em)
    you can access TIS and have all the info about every disassemble and reassemble
    procedure for anything toyota has...get all the docs in one go for anything you
    might think of taking apart.....
  13. May 5, 2013 at 11:49 AM
    Hot Taco
    Richfield, WI
    FYI... for those of you interested in painting your mirror covers, I took apart my mirrors today to figure it out. See my first post for details.
  14. Sep 5, 2013 at 9:40 AM
    m32
    m32 Well-Known Member
    Edwin
    2013 DCSB TRD
    Thanks for doing it. Is it possible to pop out the cover without taking off the mirror?
    Edwin
  15. Sep 5, 2013 at 9:50 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Port Arthur/Lubbock, Tx
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Hehehe Philpott Toyota
  16. Sep 5, 2013 at 2:46 PM
    Hot Taco
    Richfield, WI
    Maybe, but it'd be pretty hard hard. You'd have to move the mirror enough to see the tabs that hold the cover on so you could get at them with a screwdriver. Popping off the mirror is easy so I'm not sure why you'd skip that step anyway.
  17. Sep 5, 2013 at 2:51 PM
    m32
    Edwin
    2013 DCSB TRD
    Thanks for the input. I Was thinking more of just popping them off from the outside cover (I read somewhere on here that someone did that). I prefer not to take off the mirror only b/c I am afraid of cracking it
    Edwin
