How to remove outer CV joint from axle
Discussion in '1st Gen. Tacomas (1995-2004)' started by betterbuckleup, Jun 20, 2024.
  1. Jun 20, 2024 at 12:05 PM
    betterbuckleup
    betterbuckleup [OP] Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Anybody know how to remove the CV shaft, cage, & joint from the outboard portion of the CV axle?
    I'm making a trail spare and only want the outer bit. Last time I did it, I just cut everything up, but would rather not have to do that again.
    Not sure how these are assembled at the factory. A large press perhaps?
  2. Jun 20, 2024 at 5:11 PM
    betterbuckleup
    Ian
    Concord, CA
    Nevermind. I just ended up cutting the cage. Pretty sure heat is involved for assembly at the factory. Lots of heat affected zones on the outer cup where the balls seat
