How to remove Plastidip remnants?
Discussion in 'Detailing' started by TacoBrah, Feb 7, 2014.
  1. Feb 7, 2014 at 9:41 PM
    TacoBrah
    TacoBrah [OP] Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Ive tried using a popsickle stick, toothpick, plastic wall anchor, it just wont come off. Should I try a paint thinner or something?
    8D71F7B8-CEE6-4F29-BB8B-023912C1E13C-122_fc8d72cd36676936926fab92098166db48bc81fe.jpg
  2. Feb 7, 2014 at 9:43 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Try goo gone and wd40 before paint thinner.
  3. Feb 7, 2014 at 9:53 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Are you sure that's 'derp?
    How long was it on the rim? It looks to me more like corrosion.
  4. Feb 7, 2014 at 10:05 PM
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    Rubbing alcohol.
  5. Feb 7, 2014 at 10:14 PM
    TacoBrah
    Sean
    100%, I have had that there for over a year, couldnt get it off so I said F it. I have finally come back around to it and I want it off.
    Will that work better than Goo Gone?
  6. Feb 7, 2014 at 10:18 PM
    Germ
    Arizona
    2013 TRD OR DCSB
    Either would probably work fine. I just happened to reach for the alcohol when I took some off.
  7. Feb 10, 2014 at 10:29 PM
    TacoBrah
    Sean
    Alcohol didnt do too good, gonna try acetone tomorrow. Wont cause any problems will it?
  8. Feb 10, 2014 at 10:37 PM
    Manwithoutaplan
    ID
    I know how you get rid of it.... don't use the crap.
  9. Feb 10, 2014 at 10:45 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Go careful so you don't damage the factory coating.
  10. Feb 10, 2014 at 11:17 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    have you used a pressure washer? Simple green solution soak with plastic bristle brush and then pressure washer.
  11. Feb 10, 2014 at 11:22 PM
    TacoBrah
    Sean
    I have used a pressure washer at a self serve car wash, it got most of it off. I have used simple green, did not soak it though, I will have to try my plastic bristle brush next.
  12. Feb 10, 2014 at 11:24 PM
    davidjmay
    davidjmay Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
    Let it soak in wd-40. Should come off with some scrubbing after that
  13. Feb 10, 2014 at 11:25 PM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    spray it with wd-40 and let it sit. should just wipe off after 10 minutes
    or gasoline will work too
    :thumbsup:
  14. Feb 10, 2014 at 11:36 PM
    Toyota Tacoma
    Toyota Tacoma Well-Known Member
    Brady
    Kelowna, bc
    dbl cab long box
    Suspension: -Bilistien 5100's all around -Add a leaf -Firestone ride rite air bags Performance: -K&N cold air -Borla cat back Stereo: -Pioneer AVH-X2500BT head unit -Kenwood 1400 shallow mount 12'' sub in custom box -Alpine 1100 amp -Alpine 400 4 channel -4 energy component 6.5's Wheels/tires: -17x9 with 4.5 backspacing XD hoss rims with 33'' bfTreadwright gaurd dogs and spidertrax spacers Looks: -Satoshi grille made by myself -Hood, front bumper, grille, roof, tailgate and rear bumper plasti-dipped. -BHLM -eyelids -matted out tailights -Tacoma bed mat Small mods : -Trailer 7 pin replaced and moved into bumper beside licence plate -Removed mud flaps -Repainted frame/lower a-arms, skid and rear diff/housing with por15 -Led bulbs -Interior lights replaced with blue led's -Beep on lock added
    I used goo gone to remove an entire roof that was too thin.
    Tried all of the above suggestions and goo-gone worked best.
    Apply generously, let sit for 5 minutes, use a credit card to get the bulk off then just wipe the rest away.
  15. Mar 6, 2014 at 5:53 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Acetone worked on chrome, my dad accidentally split some on my chrome bumper and it ate right through it :rofl:
  16. Mar 6, 2014 at 6:27 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    I wonder if something like vegetable oil would break it loose? Maybe that and a good course pad? Might be worth a try since you probably have both available. If not then I would try the least aggressive first, like goo gone before I went with something like acetone. Just my 2 cents.
  17. Mar 6, 2014 at 10:16 PM
    jaeforceone
    jaeforceone Member
    Jae
    Gainesville, FL
    2013 DCLB 4X4 TRD Sport
    acetone will erase everything do not use. try gasoline but it may be some corrosion that has formed there if your plastidip was on there for a long time.
  18. Mar 6, 2014 at 10:16 PM
    nieb15
    nieb15 Well-Known Member
    Justin
    Auburn, CA
