how to remove scratch on the dash board
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bra, May 4, 2009.
  1. May 4, 2009 at 7:40 PM
    bra
    bra [OP] Well-Known Member
    2008 AC 4X4 TRD sport
    Badges off
    Hello guys my cat had make some ugliy scratch on my dash board it is not very very scratching but we can see it
    Do you think i can remove them of something?
  2. May 4, 2009 at 7:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    about all i can think to do is go over the area with some plastic polish and then use a good interior cleaner on it. interior scratches are pretty hard to get rid of unless they are pretty minor.
  3. May 4, 2009 at 7:48 PM
    bcash9407
    bcash9407 Member
    Buena Vista, VA
    06 Tacoma
    Flowmaster 40 Series
    keep your cat out of your truck....rule number one!!!
  4. May 5, 2009 at 5:12 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Good luck fixing your dash-I've never had any luck getting them out.
  5. May 5, 2009 at 6:11 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Add more to mask it...
    Or replace it. GL!
  6. May 5, 2009 at 6:21 AM
    BlackRig
    BlackRig Well-Known Member
    Craig
    NE Ohio
    2021 SR5
    I read a post on here awhile ago about using a lighter to heat it up lightly and dab it with your finger. But don't quote me on it. I'm yet to do it.
    Try searching the detailing section.
  7. May 5, 2009 at 6:24 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    I could see that maybe working but... also see it just making more of a disaster. If you try it'd I'd suggest taking a door panel off or something, scratch the back of it, and test it there first for some practice. Probably I'd use a scraper or something other than a finger that could leave prints embedded and oily residue.
    Also depending where the scratch is at, I wouldn't throw an open flame anywhere near the airbag... you know just in case.
  8. May 5, 2009 at 6:29 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Plastic does have a tendency to return to it's original shape/position when heated...but I just don't see flame + dashboard going well...A heat gun would be a little more comfortable for me to try- but even that would make me nervous.....
  9. May 5, 2009 at 6:34 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    On the lines of what Brunes suggested, I have used a hair dryer successfully with scratches. Carefully heating it up & using something for a filler like a color matched crayon. It just cannot be very large, deep gouges. Worked great on fine ones I had. Take your time & work slow. :thumbsup:
  10. May 5, 2009 at 9:02 AM
    cjag
    cjag Active Member
    Georgia
    07 TRD OFF Road 4x4
    www.cardomain.com/ride/2537226
  11. Nov 13, 2009 at 11:41 AM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    lmfao, what a smart-arse.
  12. Feb 16, 2012 at 8:50 PM
    puttdog
    puttdog Member
    I got some ideas from this thread and thought I would post back for the possible benefit of the community.
    my scenario included a number of easily noticeable scratches in the grey plastic beneath the radio and AC controls as well as one deep scratch in the silver trim area around the AC vent (like a dumb@** I put these there myself installing the Grom iPod/USB accessory).
    grey plastic beneath the radio and AC controls:
    carefully buffed out the scratches starting with 220 sandpaper, then 300, then 600. I went ahead and sanded an area larger then the scratches (2.5"x4") to make it look more even. once this was done, the plastic is fairly smooth, but much lighter in terms of color than the rest of the console area. cleaned the area with light soap and water and allowed to dry. masked off the entire portion of the console area (not just the part I sanded) with thick masking tape and then applied 2-3 coats of "Rust-Oleum Painter's Touch Satin Clear 249845" found at the local Ace hardware.
    the results were good. there is a natural texture to the console and dash plastic, so the area that I sanded is slightly smoother than the rest of that console. moreover, the satin clear coat is slightly glossier. bottom line, if somebody didn't point it out to you, you would never notice any work had been done.
    silver trim area around the AC vent:
    buffed out the offending scratch using the same sandpaper grades. keep the sanded area small this time. masked off the adjacent dash areas. applied VERY light coats of "Dupli-Color Bumper Coating FB108 MED SILVER". Make sure you have really masked off the rest of the dash well, and hold the can way back to ensure a very light coat, otherwise it will run or crackle. Let it dry, then repeat.
    results were excellent. looks like new.
    it was a lot of work for a couple of scratches, but I suppose I learned something in the process. I hope this helps somebody else.
  13. Feb 16, 2012 at 8:54 PM
    TurfTaco
    TurfTaco Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    If its on the colored part-heat. If its on the black part-good luck
  14. Feb 16, 2012 at 9:23 PM
    agapeguy58
    agapeguy58 Member
    San Antonio, Tx
    Toyota Tacoma
    What about a dash mat?
  15. Feb 16, 2012 at 11:44 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Hmmm, a cat fur one?
