How to Remove Seized Wheel
Discussion in 'Technical Chat' started by hladun, Jun 28, 2017.
  1. Jul 1, 2017 at 8:10 AM
    #41
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Jupiters Moon "Europa", ARB 390.4 Million mile snatch strap, and some choice curse words.
    Travlr likes this.
  2. Jul 1, 2017 at 8:12 AM
    #42
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Spit, teenage angst and a good RomCom.
  3. Oct 19, 2021 at 8:47 AM
    #43
    gnichola
    gnichola New Member
    Guy
    2017 Silver Tacoma TRD Off Road
    Gentle turning of the jack pushed the wheel right off. [​IMG]
  4. Oct 19, 2021 at 9:11 AM
    #44
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    yay this thread got revived.
    Next up, removing seized drums with a air hammer.
    6 gearT444E likes this.
  5. Jul 25, 2023 at 12:56 PM
    #45
    rizrox
    rizrox Well-Known Member
    Northern CA
    2021 Tacoma TRD OR AC 4x4 AT
    FULL BUILD BELOW (hover cursor here) ----------------------- BUILD UPON DELIVERY (all OEM) Premium OR Package Technology Package LED Headlights and Fog Lights All Weather Floor Liners Door Sill Protectors 5" Oval Tube Steps Black Exhaust Tip Black Mud Guards Remote Tailgate Lock Tailgate Insert Black Bed Mat Bed Lighting Kit Glass Breakage Sensor ——————————————————————— MODS AND ADDITIONS JDMCAR Glove Box Organizer JDMCAR Center Console Divider & Tray SaBellCo Tailgate Lock OEM Spare Tire Lock Total Chaos Bed Stiffeners OEM 4x4 Badge OEM Blackout Badge Overlays OEM Bed Header 3rd Accessory Rail Cubby Covers by Mike Williams OEM Bed Header Rail End Caps Sealed Weatherproofed Bed Rail Caps A/C Drain Hose Mod Bedside Outlet Pigtail Extension Cord DECKED Truck Bed Storage System w/Locks Snugtop Sport Hi-Liner Camper Shell (debadged) Cord Management BottlePro Cup Holder Adapter BCP 4” Full Folding Mattress ESI Rok Block and Ultimate Tailgate Seal Glow-in-the-Dark Camper Bed Indicators CBoy808 Gloss Black OEM Style TRD OR Bedside Decals YakGear Tailgate Lift Straps OEM Pro Grille & Garnish Yakima SkyLine Shell Roof Rack Cab Floor Dewalt T-Stak Storage Boxes and Carpet Covering Paracord Gear Lines and Carabiners on Camper Shell Ceiling CA Heritage Black & Yellow License Plates Yakima FatCat EVO 6 Ski Rack / Dakine Aero Rack Pads Custom Tailgate Pad Custom Tailgate Drink Holders Offroam MagSafe Magnetic Charging Phone Mount SeaSucker Vacuum Mount Hand Grips for Inside Closing of Snugtop Hatch Petite Café Curtain Rods with Custom Camper Shell Curtains and Tieback System COVERKING Saddleblanket Custom Seat Covers: Black BF Goodrich KO2s
    Jokes or no jokes this thread saved my ass yesterday!!! Thanks! Out in the middle of nowhere. Found one bar of cell service just to find this post. Yee!
    p.s. OP is correct. Easy and no damage to report.
    Steves104x4 and Travlr like this.
  6. Jul 25, 2023 at 1:03 PM
    #46
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    ^^^... this
  7. Jul 25, 2023 at 1:20 PM
    #47
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Loosen lug nuts one turn. Start truck and put in gear. Hit the throttle, turn the steering wheel and slam on the brakes. It’s Miller time.
    Tac2021 likes this.
  8. Jul 25, 2023 at 2:24 PM
    #48
    hladun
    hladun [OP] Well-Known Member
    Alberta
    Tacoma
    It's been nearly seven years since I made this post and I can't believe the amount of crap that it has accumulated. I've disabled replies so keep that crap coming boys. To rizrox...glad it worked.
    rizrox likes this.
  9. Jul 26, 2023 at 3:42 AM
    #49
    Tac2021
    Tac2021 Well-Known Member
    Phil
    2021 SR5 Drk Grey Met Dbl cab 4 x 4
    none yet
    Did this technique many times of over 50 years of cars and trucks, always worked, but I sprayed each lug after loosening the nuts, kroil works the best, or mystery oil cut with diesel or kerosene, 50/50 mix.
    Steves104x4[QUOTED] likes this.
  10. Mar 17, 2025 at 11:49 AM
    #50
    mazz
    mazz Member
    I'm resurrecting this thread !! Because I had to come back to it several times in the past week - and wanted to tell you what worked for me.
    First off, Tacoma '16 .. I haven't taken the tires off since I had a place put on new tires about 30,000 miles ago. Been through east coast winters and backing up into the salt to launch a boat over the past summer.
    Last week I tried taking off the front tires to change the brakes and... siezed! So I used the rubber-mallet-on-the-sidewall trick and that worked. Surprising.
    Then I go to rotate the tires, so I try to take off the rear tires. Siezed! This time, I tried the rubber mallet trick, PB Blaster, I even tried the trick you folks have been beating on (loosened lugs and driving up and back on the driveway). Nothing was working.
    Friend of mine told me to take my short-handled sledge hammer (one of those 3 or 4 pound sledges with the short handles) and wack the tire rim on the inside (right where the tire meets the rim), rotating the tire as I go as needed. After some good hard wacks, rotating the tire like 45 degrees after a few swings, and it came off. Same thing on the other side - worked.
    Just adding that to the thread - hope it helps someone else.
    After I got my wheels off, I scoured the rust off, blasted it with some brakleen, then applied small thin layer of anti-sieze... no idea if that will help but... can't make it worse!
    Steves104x4 likes this.
