How to remove serpentine belts???
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, Jul 15, 2012.
  1. Jul 15, 2012 at 9:37 AM
    x2468
    x2468 [OP] Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Okay, i have a ton of belt noise from the engine bay. I know one or more of my pulley bearings is probably bad. I tried running a wire brush under the belt as it was going to clean out any sand or dirt but it had no effect.
    Everyone always says "just take the belts off one by one and see which one is the problem". but how?
  2. Jul 15, 2012 at 9:40 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    the belts on the 3.4 are easy to remove. all of them have tensioner bolts that increase or decrease tension then another bolt is tightened to hold it in place. alternator is one location power steering pump is another and on the a/c compressor is another loosen the pulley on bottom then loose the tensioner bolt
  3. Jul 15, 2012 at 10:19 AM
    x2468
    and then to put it back on, how do i know how tight to put the tensioner?
  4. Jul 15, 2012 at 10:27 AM
    2000GTacoma
    Snow Hill NC
    feel of the belts as you are tightening them. to tight is just as bad as too loose. you want to be able to move the belts about a 1/4 to 1/2. if you have never taken off belts or replaced them might want to get someone else to do it.
  5. Jul 15, 2012 at 10:44 AM
    KS WRAITH
    KS WRAITH Well-Known Member
    Las Vegas
    2007 Tacoma 2WD 2.7L 5Lug
    •K&N Intake P/N: 77-9026KP •Black Badges •Toy Yoda Decal •TacomaWorld.com Decal •Four Banger Decal •BF Goodrich All-Terrain KO2 30x9.5xr15 •KMC XD Enduros 15x7 •2" Ebay Spacer Lift •1.5"-2" Ebay AAL •Longer U-Bolts from Fat Bob's Garage P/N: 5L-UB •Bilstein HD 4600 Strut (5 Lug): Left P/N: 24-185042, Right P/N: 24-185066 •Bilstein 5100 Rear Shocks (6-Lug): P/N: 24-186728 •UWS Toolbox P/N: TBS-63-A-LP-BLK •Lots of Patches •Uniden Pro505XL CB Radio
    Your Tacoma has an automatic tensioner it will go to the correct tightness if there's nothing wrong with i.e. bad tensioner. You'll need either a socket wrench or two wrenches (one that fits on the tensioner bolt and one for leverage) on a v6 you place the wrench on the bolt in the center of the tensioner pulley and rotate it counterclockwise to release tension on the belt. Remove belt and slowly release tensioner. On the v6 before installing belt, lock the tensioneras follows: turn tensioner counterclockwis, align the two holes on the tensioner assembly and insert a 0.24-inch dowel pin or drill bit through the two holes. Install the belt. Be sure to route it correctly. Remove dowel or drill bit and tension the belt. Make sure that the belt I'd centered on all pulleys......or at least that's how it works on a 2nd gen. :D Hope it helps ya.
  6. Jul 15, 2012 at 11:08 AM
    2000GTacoma
    Snow Hill NC
    1st gen tacomas do not have auto tensioners on the accessory drive belts. power steering, ac, alternator. you must manually set the tension. the timing belt does but slack must be put on the correct side.
  7. Jul 15, 2012 at 1:11 PM
    x2468
    Oy. Okay. Two different answers here.
    As for new pulleys/bearing, searching the forum tells me Gates makes the best bearings. I cant beleive how fragile these stupid things are. A little water and they're toast. Someone should make waterproof pulley bearings! Or at least servicable bearings so you can clean them out and lube them when need be. This shit is ridiculous.
  8. Jul 15, 2012 at 1:56 PM
    2000GTacoma
    Snow Hill NC
    actually its not that bad. are you talking about the drive belts or the timing belt?
  9. Jul 15, 2012 at 2:11 PM
    x2468
    i'm talking about the idler, A.C., P.S., alternator and whatever other pulleys are right there between the engine and fan that are exposed to the elements.
  10. Jul 15, 2012 at 2:19 PM
    2000GTacoma
    Snow Hill NC
    ok thats accessory belts. they have bolts that tension the bolts and bolts that lock down the other bolts.
  11. Jul 15, 2012 at 2:48 PM
    x2468
    well id like to take the belts off and see which ones are the noisiest instead of just ordering everying single one. Gates only seems to list the A.C. tensioner, http://opticat2.net/NavigatesBeta/f...ssenger+Cars+&+Light+Trucks&Type=Light+Trucks so Idk where to get the idler or other pulleys i may need.
    Is it true that if the bearing on the alternator is bad you need to rebuild or replace the whole alternator???
  12. Jul 15, 2012 at 3:04 PM
    2000GTacoma
    Snow Hill NC
    i personally would go back with toyota belts. i got all my belts timing belt to from toyota for about 115. there are also places online you can get toyota parts from. rockauto.com is another
  13. Jul 15, 2012 at 4:22 PM
    x2468
    Well assuming i replace everything. How many pulleys do i need to buy? Idler, ac, ps, tensioner..... that it, or am i wrong? I know its 3 belts.
  14. Jul 15, 2012 at 5:09 PM
    2000GTacoma
    Snow Hill NC
    its probably your idlers
  15. Jul 15, 2012 at 10:32 PM
    x2468
    I'm thinking AC too.
  16. Jul 15, 2012 at 11:38 PM
    x2468
  17. Jul 16, 2012 at 6:18 AM
    2000GTacoma
    Snow Hill NC
    then that is going to be costly. the pulley rides on the shaft that goes into the compressor not just a pulley swap. a compressor swap which would mean evac the system then recharge it
  18. Jul 16, 2012 at 7:28 AM
    x2468
  19. Jul 16, 2012 at 8:50 AM
    2000GTacoma
    Snow Hill NC
