How to remove shark fin antenna off my 3rd gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by magicgus323, Oct 29, 2018.
  1. Oct 29, 2018 at 3:13 AM
    magicgus323
    magicgus323 [OP] Well-Known Member
    Gustavo
    Visalia Ca. East LA LBC
    2016 White Tacoma Sr 2.7
    TRD rims and suspension, TRD grill, stereo iPhone mirroring stormtrooper decal backflip bed cover painted bumper and mirror caps
    Tried removing had a hard time couldn’t do it dont want to brake it I just replaced my whole stereo unit I have the sr. I got it off a sr5, my radio is not working after I did the switch because I think I need the antenna too off the sr5 new stereo has radio and traffic and eco and apps as It did not have any of those features before on my old stereo so guessing it’s the antenna so it could work
  2. Oct 29, 2018 at 5:46 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    The shark fin antenna part number is the same for the SR and SR5, so you don't have to replace that. Traffic comes from HD radio stations, if I remember correctly. If you can't receive those stations in your area, you won't get traffic. Eco would have to have some connection to your ECU/BCM, or some other computer. If you didn't have Eco before, it might be tough to add.
    It's early, I'm tired, take all of this with a grain of salt.
  3. Oct 29, 2018 at 9:02 AM
    magicgus323
    Gustavo
    I’ve never had eco and it worked perfectly as soon as connected it plug n play I’ve seen a forum about someone replacing it I’ll let you know today I have antenna already I believe it should work with new antenna they are different since stereo is different
  4. Oct 29, 2018 at 11:13 AM
    Ravnikar610
    Ravnikar610 Well-Known Member
    Minnesota
    2016 OR DCSB
    I would double check the wiring. Did you have hd radio before the switch?
    magicgus323[OP] likes this.
  5. Oct 29, 2018 at 11:43 AM
    magicgus323
    Gustavo
  6. Oct 29, 2018 at 11:43 AM
    magicgus323
    Gustavo
    I just had normal radio before
  7. Oct 29, 2018 at 11:59 AM
    VicNic3
    VicNic3 Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
  8. Oct 29, 2018 at 2:01 PM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    only time i get HD radio stations, is when im at a high elevation, and the signal is strong, otherwise, forget it
    Kilokato and magicgus323[OP] like this.
