How to remove spare tire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PatinoTheLatino, Sep 18, 2016.
  1. Oct 4, 2018 at 8:17 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    This unsecured way of having the spare mounted, is a sure way to ware a hole in the sidewall of the spare from vibration against the rail. I have seen it with my own eyes from this exact type of mounting. :burp:
    Let alone it will just fly out in an accident potentially causing others harm which you will be responsible for. :spy:
  2. Oct 4, 2018 at 9:12 AM
    ENZO99
    ENZO99 Well-Known Member
    Vince
    SOCAL
    SPORT
    Bed Mat, Snugtop Sl. Gentex, Rock Sliders by shmellfab
  3. Oct 4, 2018 at 2:56 PM
    DougSD
    DougSD Well-Known Member
    Doug
    San Diego, CA
    2015 TRD Tacoma
    Icon front 2.5 Coilovers, Fox 2.0 rear shocks, Hankook A/T tires
    new models got chains huh? mines a wire cable ..interesting
  4. Oct 4, 2018 at 7:53 PM
    Steve721
    Steve721 Well-Known Member
    Boston
    2009 Speedway Blue, TRD Sport
    When I bought my Tacoma last year, one of the first things I did was drop the spare and inspect it. Made sure it has air in it, and also know how to remove the tire from under the vehicle. Always using the tools supplied with the truck. I have a great deal of money in tools in my garage, but none of that means anything when the tire goes flat on the highway.
  5. Oct 4, 2018 at 8:02 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    For some history. Originally they were chain hoist then they screwed up and installed those cheap cable hoist that would corrode and drop the spare on the highway because the tip pulled off the cable ( lack of maintenance grease ), now we are back to something durable chain hoist
  6. Oct 4, 2018 at 8:05 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    First, flip the tire so the air valve is pointed down instead of up. Much easier to check pressure on a routine basis.
    2nd, drop it at least once a year in your driveway and lube the chain and mechanism with something like PB Blaster.
    And as for the hook, it is used for turning the jack and to snag the chain/tire and pull it out from under the bed. You're going to get dirty regardless but there is enough slack so you don't have to get all up under there. Crank it all the way out and drag it out. A tarp, cardboard, or moving blanket on hand should keep you from too much ground contact. No need to put tire in the bed. Work smarter, not harder.
  7. Oct 5, 2018 at 11:35 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    My notes about the spare tire thing:
    Yes mounting the spare with the air valve down (face down) makes it easier to check the pressure, but my truck has TPMS issues with this mounting. The issue went away immediately after flipping the spare to a face-up orientation. Yes it sucks trying to air it up, but for me that is preferable to having a useless TPMS. Maybe I'll get one of those air valve extender thingys: https://www.zoro.com/cherne-industries-extension-hose-air-36-in-length-274038/i/G1324662/
    When the spare is mounted under the bed, it's pretty difficult to see the winding mechanism where the rod tool goes. The spare is obstructing most of the view, the only part visible is about 8 inches ahead of the license plate. Once the spare is off, it's all exposed but at that point you don't really need to look at it anymore.
    Putting the spare in the bed with a strap only solves the issue of crawling underneath to get at it. Besides the bed-rail and strap possibly wearing into the tire, it also invites vandals over for a quick stab (people are douchebags), and also it compromises bed storage. Under normal circumstances, I only pull the spare about every 6 months (keep it slightly overinflated). And if I do get a flat, I have a rainsuit and tarp ready to go. In my opinion it's not worth mounting in the bed.
    Finally, I wish Toyota would provide a better tool -- the threads are nearly stripped on those tiny wingnut fastener things. Also Toyota could make a smoother path from the license plate hole into the winding mechanism.
  8. Oct 5, 2018 at 11:40 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    First time I took my truck in for an oil change at the dealer they told me there was 0 pressure in the spare. They aired it up. It's been fine ever since. Factory forgot perhaps?
  9. Oct 5, 2018 at 2:23 PM
    Soggy Donkey
    Soggy Donkey Erstwhile zetetic, No-Hoper.
    East Nyack, NY
    2011 Tacoma DCLB
    Every Spring, when the sun comes out, one of my colleagues (I'm a high school teacher) marches his class out to the parking lot and has the kids do it. Most of them have never done it (or even seen it done) before.
    Biscuits, boostedka and b_r_o[QUOTED] like this.
  10. Oct 5, 2018 at 7:46 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    See this, it works great.
    Mandy3206 said:
    Ever had to remove the spare tire?
    Have you noticed that even if you practiced doing it, it's PITA to engage the rod on the elevator?
    Grab a PVC 1 1/2" sanitary pipe and cut a 14" section, drill a hole about 1" from the end and install it with a zip tie as seen in the pictures, works like a charm and total cost was $2.35 for the whole 10ft pipe.
    Why didn't Toyota did that in the first place?
  11. Oct 5, 2018 at 7:54 PM
    GT_Charlie
    GT_Charlie Well-Known Member
    You're damn straight it is! I am that dad.
    The procedure is a lot like on the Ford F-150: Rod, key, hole (not "Whole" lol), and lower. It's dirt simple.
    Charlie
    Biscuits, nobescare and Jimmyh like this.
  12. Oct 6, 2018 at 6:45 AM
    Steve721
    Boston
    That's a nice mod. Plus I have some assorted sizes of PVC in the garage. But with me, the size I need will be 2 inches to short. But I'll look. Nice write up. Thanks.
    Biscuits likes this.
  13. Oct 6, 2018 at 7:49 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I remove the spare tire every time I change the rear diff fluid. Makes changing the fluid a lot easier and helps keep the tire maintained...two birds kind of thinking.
  14. Oct 6, 2018 at 7:55 AM
    81shark
    81shark Well-Known Member
    Go get a frame swap. Mine came with cable. I now have chain
  15. Oct 8, 2018 at 10:16 AM
    #35
    DougSD
    Doug
    San Diego, CA
    2015 TRD Tacoma
    ha I dont need a new frame... no rust
    my cable seems fine and I grease it every 6 months
  16. Oct 8, 2018 at 11:03 AM
    #36
    Blockhead
    Pittsburgh, Pa.
    I grease mine almost daily...huh, wait a minute...what were we talking about? :anonymous:
    DougSD[QUOTED] likes this.
  17. Oct 8, 2018 at 11:42 AM
    #37
    vtdog
    vtdog Well-Known Member
    NH
    #37
  18. Oct 8, 2018 at 11:50 AM
    #38
    TXRailroads73
    TXRailroads73 RÖCKIN'ROLLIN',BEER,YOTAS,TACÖCRÜE,MAX/GEMMA
    Adam
    The Lone Star State, RGV, TEXAS
    '23 TRD PRO
    None all stock
    I need new winch, traveling down road at 55mph came across some railroad tracks, spare tire busted loose from winch line, problem is, ther are 4 bolts to remove, only 2 can be taking off, the other 2 guess I need to remove bed to access the 2 remaining bolts
  19. Oct 8, 2018 at 12:02 PM
    #39
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I think that you have the wrong link in your post, unless you're saying you stuffed delicious Indian food, an Indian cook, or a pressure cooker into your spare tire housing. If that's the case, well, that's interesting.
    #39
    Jimmyh likes this.
  20. Oct 8, 2018 at 2:14 PM
    #40
    Jimmyh
    SC
    2012 Prerunner SR5
    Replace it with the chain version.
