How to remove spray paint on the tail light after I try tint it?
Discussion in 'Lighting' started by wing103, Aug 14, 2011.
  1. Aug 14, 2011 at 5:58 PM
    wing103
    wing103 [OP] Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    Like the title said, I try to spray paint to tint the tail light, but i did not like the result, how can I clean those paint off? Please help.
  2. Aug 14, 2011 at 6:00 PM
    GA_TACO4x4
    GA_TACO4x4 Well-Known Member
    here 'n there
    07 DCSB 4x4
    marathon superhide max-4 seat covers, weathertechs, maglite mod, 20% tint, 2" leveling kit, leaf spring tsb.
    wet sand with 600 grit to get most of it. then move on to 1000 then 2000 to smooth it out. after that, hit it with some polishing compound to get the clarity back
  3. Aug 14, 2011 at 6:03 PM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    I use nitro fuel from RC cars. It does a good job but is not as hot as thinner to bite into the polycarb or acrylic lens. Learned about this method at work when we were trying to design a cleaning process to get overspray off a shifter PRNDL that we do.
    Just google removing overspray from polycarb and you will get lots of methods.
  4. Aug 14, 2011 at 6:07 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    Depends how dark it is, if its extremly dark try rubbing a very small amount of gas on the lights using a soft shop towel and rubbing hard. remove as much as possible. (if you use too much it can crack your plastic) Then wet sand it with 400 using a lot of water and little pressure, then use 600, 800, 2000. to polish it. After polishing with 2000 and making sure there are no scratches use Turtle wax rubbing compound and buff the lights. Then try miguires plastix or other plastic cleaner. This should leave you with a glossy new looking light. If you see scratches sand it down with finer grit. I messed up mine the first time i tried, so i did this gave it another shot and it came out perfect. :D
  5. Aug 14, 2011 at 6:09 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Bummer, good luck. I found a local bosy shop to do mine. $70.00 and they are perfect. Took one day.
  6. Aug 14, 2011 at 6:11 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Laquer thinner
  7. Aug 14, 2011 at 6:12 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    ^^^^This
  8. Aug 14, 2011 at 6:13 PM
    PLC721
    Patrick
    Chandler, Az
    Ask me how I know:rolleyes:
  9. Aug 14, 2011 at 6:26 PM
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
    how u know?
    :D
  10. Aug 14, 2011 at 6:41 PM
    Treedawg37
    Treedawg37 Well-Known Member
    Barry
    Central, Alabama
    '11 Tacoma DC 4X4 SR5 SB,
    BHLM, tinted tails, weathertech mats & visors, sportsman"s camo seat covers, diff breather mod.
    i just did mine 3 times and took it off everytime. just wet sand it with 1000 grit and polish back to shine. simple
  11. Aug 14, 2011 at 6:50 PM
    TKOMA
    TKOMA 408 TACO
    San Jose, Ca
    '16 Doble Cab, Long Bed, TRD Sport
    Tires only, not planning any major changes yet.
    Try using Denatured Alcohol, lacquer thiner or MEK. (Watch out with the MEK). One of those will remove the over spray.
  12. Aug 14, 2011 at 8:25 PM
    donaldwagner
    donaldwagner -Don-
    Donald
    College Park, Orlando
    2013 single cab 4x4
    laquer thinner
  13. Aug 14, 2011 at 10:41 PM
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Just have to watch the amounts, lacquer thiner is pretty strong, you can scar/crack your lights if u use too much. sanding works best. Sprayed custom cabinets for last job, lacquer thinner eats everything.
  14. Jul 3, 2012 at 5:46 AM
    WhiteTacoma09
    WhiteTacoma09 Well-Known Member
    Curt
    Florida
    09 Prerunner access cab
    ZXE Headlights Drop in k&n filter Kobalt slim toolbox Tinted 17" FJ trail edition wheels OEM foglights 265/70/17 BFGs AVS vent visors Pioneer AVH-X1500DVD
    Gasoline on a rag. It actually works awesome!!!
