How to remove steering wheel?
Discussion in '1st Gen. Tacomas (1995-2004)' started by austinramsay, Nov 9, 2013.
  1. Nov 9, 2013 at 3:01 PM
    austinramsay
    austinramsay [OP] Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    Is there a walk through or guide to removing the steering wheel on an 02 tacoma around? Tried searching and found a couple but the links to the manuals were all out dated. Or can someone explain to me how to do it? Thanks
  2. Nov 10, 2013 at 10:54 AM
    austinramsay
    Austin
    Yuma, Arizona
  3. Nov 16, 2013 at 2:28 AM
    lunch box
    lunch box diesel mechanic
    2000 trd tacoma
    diff lock grey wire mod k&n77series cold air intake 2nd gen s/c water meth injection 7th injector urd 5100s lift all the way around add a leaf new excedy clutch and rear main seal scan guage 2 wet okole covers.bazooka tube.& some minor body stuff.TRD supercharger,URD 7th injector kit
    never done it on a tacoma but remove batt for sure to disable air bag remove the cover you should see threaded bosses set up a puller tool and remove it make sure you disconnect all wiring pulling a wheel is not hard also mark everything with a paint pen so when you reinstall your wheel is allighned corectly......why you pulling the wheel
  4. Nov 16, 2013 at 8:17 AM
    02coma
    02coma Well-Known Member
    la puente
    02 dc
