How to remove swirl marks
Discussion in 'Detailing' started by Mhicks7714, Feb 22, 2016.
  1. Feb 22, 2016 at 11:45 AM
    Mhicks7714
    Mhicks7714 [OP] Member
    Alabama
    2012 double cab prerunner sr5
    Rough Country N2.0 3" suspension lift, 4" Westin pro traxx step rails
    Hey guys, was looking for some insight on how to remove those stupid swirl marks from my truck. Drive a black 2012 Tacoma and very ocd about the cleanliness of it. So it's very well maintained, but I can't seem to get the swirls out. What's the best detailer y'all use?
  2. Feb 22, 2016 at 1:51 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    You have access to a DA polisher? That's the best way to attack the swirls. Meguires Ultimate Compound/Polish should do the job.
    You might also try Meguires Black wax. But a DA is likely necessary to get rid of the swirls. Compound/Polish would be more effective.
    I've read that HD Speed is also a nice all in one that has some good cut. $14.99 on Amazon.
    Basically, unless you wanna spend hours and hours and hours by hand- you'll need a machine.
  3. Feb 22, 2016 at 8:49 PM
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    What he said but the standard entry level DA polisher is the Porter Cable 7424XP. Also look at HD version: Another cheap entry one is Griots Garage 6", which I believe has a lifetime warranty and also available as HD.
  4. Feb 22, 2016 at 8:52 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Yeah, get a machine if you want to effectively remove swirls from your paint. You can't do it by hand no matter how much you use your hand to jack off. It's just not fast enough.
    RI_Taco likes this.
  5. Feb 22, 2016 at 10:25 PM
    NMTrailRider
    New Mexico
    Yep, lifetime warranty on the GG6.
    I just read a thread over on AG where someone was very happy with the filling capabilities of the Meguires Black Wax. He posted pics and it looked like the polishing oils in the Black Wax did do a stellar job at masking the swirls on black paint. So, there's another option for you OP. Might be as good as you'll get by hand. Easy to find. I think it's about $13 and comes in a toothpaste-type tube.
    I'd love to see your results if you give it a try. Ultimate Polish also has a heavy oil load, so UP followed by Ultimate Liquid Wax might be an improvement as well. Lots of ways to skin a cat. By hand, I'd be trying the black wax for sure.
  6. Feb 23, 2016 at 1:40 PM
    Para8291
    Para8291 Well-Known Member
    Rob
    San Antonio
    2016 Tacoma TRD Sport
    Bilstein 5100s all around, Toyo All Terrain AT II 285/70/17, Custom Car Grill, front windows tinted at 35%, door still protectors, bed Matt, tail gate lettering, center console organizer and detailed with Adam's Polishes products
    Speed and the correct polish
