How to remove tailight on 17 TRD offroad???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaptainAwesome, Mar 25, 2017.
  1. Mar 25, 2017 at 9:57 AM
    CaptainAwesome
    CaptainAwesome [OP] Well-Known Member
    Calgary, Alberta
    so I removed the two screws holding the tailight in the truck but when I try to pull the tailight out, I am getting a lot of resistance. Is there a third bolt or some clip or something I need to release? Thanks!!!!
  2. Mar 25, 2017 at 10:04 AM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    There is probably two tabs . Pry it out with a plastic pry tool if you have one.
    CaptainAwesome[OP] likes this.
  3. Mar 25, 2017 at 10:10 AM
    CaptainAwesome
    Calgary, Alberta
    Yep. It was a little tough I had to power up and go to Super Saiyan 2 to acquire the strength to remove it
  4. Mar 25, 2017 at 10:57 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Make sure you removed the "right" bolts... I think there is 3 of them there.... It shows in the manual...
    Once you have the correct 2 bolts, it drops out....
  5. Mar 25, 2017 at 12:00 PM
    CaptainAwesome
    Calgary, Alberta
    Well they were in there tight. My driver side tail light is missing one of the bracket clips. Guess I'm going to the dealer and asking them why.
    I got the bed stiffeners done. Turned out great! Highly recommend!
    Looks like I need to buy one of those mechanics manuals for this truck...
    Thanks for the help guys!
  6. Mar 25, 2017 at 12:15 PM
    foy1der
    foy1der Well-Known Member
    W1FOY
    2017 OR DCLB
    Charlie Bravo likes this.
  7. Mar 25, 2017 at 1:51 PM
    tcjacado
    tcjacado Well-Known Member
    The tabs on the back of the tail light slide into clips. The clips sit in the holes of the body. When you pull them off sometimes the clip will stick in the hole, come out and still be attached to light fixture or have fallen off inside of the hole to the bottom. Just get new clips they are cheap.
