How to remove the 1998 Toyota Tacoma Bed
Discussion in '1st Gen. Tacomas (1995-2004)' started by netsomnia, Oct 6, 2016.
How to remove a 1998 Toyota Tacoma truck bed.
Poll closed Oct 13, 2016.
  1. Watch the youtube video where the guy ties to a tree and drags it off. :-)
    50.0%
  2. Cut off the nut
    25.0%
  3. Make a hole in the bed so you can can secure the other end of the bolt and use a wrench properly.
    0 vote(s)
    0.0%
  4. Use an impact wrench to tighted and loosen until it spins off.
    50.0%
Multiple votes are allowed.
  1. Oct 6, 2016 at 3:05 PM
    netsomnia
    netsomnia [OP] Well-Known Member
    Central/Eastern Missouri
    1998 2WD Tacoma 5 lug
    Comment or use the poll if your short on time.
  2. Oct 6, 2016 at 3:09 PM
    netsomnia
    A friend at work wondered if I needed tighten it again, spread PB blaster on and try to spin it off with impact again. I started with impact but the nut only threaded off half way and now the whole bolt turns.
  3. Oct 6, 2016 at 3:12 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    What's wrong with just removing the bolts and lifting it off?
  4. Oct 6, 2016 at 3:16 PM
    netsomnia
    Hi DaveInDenver - Yes. I want to lift it off and repair the frame with SafeT Caps, which I ordered and received. Just wondering if I am missing an undocumented trick or overlooked something.
  5. Oct 6, 2016 at 3:18 PM
    Penten
    Penten Well-Known Member
    Peter
    Iowa
    6 bolts hold the bed to the frame and then you have to disconnect the filler neck . Done
  6. Oct 6, 2016 at 3:18 PM
    netsomnia
    The bed is in good shape so I would rather not put holes in it or tie it to a tree. :)
  7. Oct 6, 2016 at 3:20 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    I don't understand why you'd do that. There are 6 bolts in the floor, 3 small ones that hold the filler neck, unplug the tail lamps and lift it off. If you have a buddy you two can probably lift it and walk it off. Crawl under, you'll see the fasteners.
  8. Oct 6, 2016 at 4:40 PM
    netsomnia
    The trouble I am having with fasteners is that the whole bolt it turning when I turn the nut. The first fastener I tried spun off quickly with impact like I wanted. Second one only came off half way before the whole bolt turned.
  9. Oct 6, 2016 at 4:44 PM
    Penten
    Peter
    Iowa
    Happened to me as well . gotta cut the bolt heads off . I havent put my bed back on yet but I believe there are welded nuts inside the bed that broke off so the bolts cant come out
  10. Oct 6, 2016 at 4:59 PM
    netsomnia
    Thanks Penten. That's what it appears to be to me too and didn't want to cut off if it was unnecessary.
