How to remove the back seats in your 2013 Access Cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CitySlicker, Jan 12, 2015.
  1. Jan 14, 2015 at 9:12 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    The bins should be the same. If you pull your "center cubby" you'll see the bins are actually one large bin that runs the entire width of the truck. The normal access cabs have a short lid, center cubby / seat belt holder. short lid. The seat delete model just has two long lids with no center cubby.
    Either way I like the delete version better.
  2. Jan 14, 2015 at 9:16 AM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    I see no reason to remove the back seat.
    It's your truck, if that's something you want to do then go ahead.
  3. Jan 14, 2015 at 10:04 AM
    CitySlicker
    CitySlicker [OP] Member
    Birmingham, AL
    2013 2wd Access Cab
    You're right, the holes do go all the way through. Can you give me a link for the plugs? I'm not familiar with them at all. Thanks.
  4. Jan 14, 2015 at 11:17 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    64716-AD010-B1 64716-AD020-B1
    $250 for the set of (rear console delete) doors .... im tempted.
    im curious if the only door thats different is the drivers side door... that would halve the cost.
  5. Jan 14, 2015 at 12:05 PM
    SprtBkr
    SprtBkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 5.7L Double Cab 4x4 Inferno
    I don't think so. Those doors look taller than the ones in my 2014 Access Cab.
  6. Jan 14, 2015 at 12:18 PM
    B737
    Kevin
    Jersey Shore
    stock
    i agree, after looking closer, both the doors are different. but they should work in later second gen AC that came with the rear jumpseats. for those of us with the rear console removed they certainly finish off the rear storage area. I fabricated a plastic cover to span this gap so the dog doesnt step in the bin, but these factory doors are a lot cleaner.
  7. Jan 14, 2015 at 2:09 PM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    I just deleted the image I had which showed part number, but Advance Auto has a stock of hole plugs, grommets, panel clips, and such in the nuts and bolts section. The ones I used were 7/16" GM panel retainers. They are a tight fit in the holes. Coat them with silicone and install them with a rubber mallet. Any similar plug should work.
  8. Jan 14, 2015 at 2:12 PM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    It's got to be both. Look at the doors (lids?). They appear to be the same size as each other based on the center-line of the truck. They each come to the middle of the tranny hump. Personally for $250 I'll leave my existing lids on and keep the bin in the middle.
    I'm sure the floor between all Access Cabs is the same.
  9. Jan 24, 2015 at 9:48 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Anyone found and/or priced the back wall panel?
  10. Jan 24, 2015 at 10:14 AM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    best bet would be a salvage yard. you can get pretty much any oem taco part for a decent price if you don't mind used.
    ive toyed with the idea of doing something to the seats but I only ever throw a coat and bag back there anyway. wish Toyota had kept the lay flat jump seats.
