How to remove the center console on your 3rd Gen Taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dammit Evie, May 23, 2019.
  1. May 23, 2019 at 7:05 PM
    Dammit Evie
    Dammit Evie [OP] Evie the Schnauzer
    IDAHO-.-. .-.. .- ... ... .. ..-. .. . -..
    2018 Tacoma TRD Sport 4x4 DCSB A/T MGM
    Exterior Mods: TRD Pro SS catback exhaust | TRD Pro Grille | Redline Tuning hood QuickLIFT | OEM Tacoma bedmat | Black running boards | Derped chrome badges | Me-So Gashole | TRD Pro 17x8Alloy wheels Interior Mods: Black Clazzio Napa Leather seat covers |Aluminum stereo knobs Engine Mods: TRD Pro Intake Air Box Up Coming Mods: 265/70R17 Falken Wildpeak tires
    Removing the center console is tedious work but the result of getting your @MESO lower switch plate installed is rewarding in itself. I'm here to document my experiences of this installation including the seat heaters installation as well.
    Meso Lower switch panel
    This the recommended method of installing the switch panel which I'm not planning to follow "unless I'm unsuccessful in removing all the bits"
    I've done lots of research for the best way possible to install the switch panel without any cutting. I'm in the process of installing my seat heaters and control switches, so found this YouTube video that's pretty concise, so I decided to remove all the bits that will facilitate removal of the piece above.
    I'll be adding more pics as I move along with my install. Here's the video that inspired me to go down this road.
    https://www.youtube.com/watch?v=gDH_rI72GEs
    ancient11, yub and xsf18cdf like this.
  2. May 23, 2019 at 7:05 PM
    Dammit Evie
    Removing the various dash/center console pieces:
    Removed the center console first
    Next side panels
    Glovebox
    Upper center console
    Now comes the hard part cutting the existing switch panel.
    First I transferred all the switches to the @MESO switch panel
    t0nyvalenzuela likes this.
  3. May 23, 2019 at 7:06 PM
    Dammit Evie
    Used an ultrasonic cutter to remove the old switch frame, I opted to cut from the rear following the existing switch plate line
    Switches installed on the new @MESO switch frame and placed on the upper center console for mocking only, next gluing it down.
  4. May 23, 2019 at 7:06 PM
    Dammit Evie
    Grinding off burs
    Gluing the new switch plate
    Gluing complete, I like the way the final product turned out
  5. May 23, 2019 at 7:06 PM
    Dammit Evie
    While I had all the dash panels removed this was my oportunity to install my new start - stop ignition button. The red button is automatically illuminated upon entry into the vehicle. This was a very brilliant mod.
    I also installed and finalized the tailgate pop-n-lock harness by @KTJO 4x4 this made the connections to the OEM harness painless
    Lastly I snapped all the panel back in their respective location without any issues.
    I also installed my seat heaters, switches and associated wiring with relays, etc.
    More to come soon.
  6. May 23, 2019 at 7:16 PM
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    subd for no reason other than I am addicted to wasting money
  7. May 23, 2019 at 7:34 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
  8. Jun 26, 2019 at 6:08 AM
    obpmem
    obpmem Well-Known Member
    Sorry in advance for the noob question. I am about to try an install my first additional switch for LED bed light. I purchased a Ch4x4 switch. In the stock panel there is room for three additional switches. Can someone direct me how to add a switch there? I cant imagine you need to take the thing apart. Do they just knock out? Thanks so much for the help/
  9. Jun 26, 2019 at 7:00 AM
    bv8ma
    bv8ma Well-Known Member
    Bill
    MA
    2017 TRD OR
    Good job! I did not do that, I simply cut it out with the whole dash in place. I made sure no wires were in my way and went at it.
    tonered likes this.
  10. Jun 26, 2019 at 8:31 AM
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    NICE OP! Where did you get the TRD button? Part number?
  11. Jun 26, 2019 at 8:35 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Oh gawd!
    I am sure that doing the trimming on a bench will get a clean install, but screw that amount of disassembly. I did all that with out removing it:
    The only parts that I removed for access were the head unit trim and HVAC panel.
    helix66 likes this.
  12. Jul 4, 2019 at 8:39 AM
    Shawkman
    Shawkman Member
    2019 Tacoma Sport TRD
    None.... yet
    @MESO any possibility of making more of these lower dash panels?
  13. Mar 13, 2021 at 9:25 AM
    Glaese
    Glaese Unknown Member
    Cris
    Country of Texas
    17 Sandy Taco Ltd
    Hey can you explain how you did it without all the disassembly? I just need to add a switch so I’m not trying to take the console apart
  14. Mar 13, 2021 at 9:49 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I just did plunge cuts with a utility blade. I cut a smaller opening and widened it until the LSP fit.
    If you have a switch blank in there, just pull the radio trim off. No fastener, just clips. The pull the HVAC panel off. To do that, you have to pull the right end of the adjoining steering trim panel as they are hooked together.
    From there, you can reach in from behind and push out the blanks or switches.
    Glaese[QUOTED] likes this.
  15. Mar 13, 2021 at 10:21 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I don't plan to take the interior apart (again), but did run into one problem when I was doing work on the truck.
    I was going to remove the front passenger side seat to install a radio, but could not for the life of me figure out how to disconnect the air bag sensor from the seat. Maybe it's my airbag paranoia, but those yellow connectors seem different than the other ones.
    Does anyone have any hints on how to do that without bunging up the connectors or screwing up the airbag system?
  16. Mar 13, 2021 at 12:24 PM
    Glaese
    Cris
    Country of Texas
    17 Sandy Taco Ltd
    Thanks for the tips should make this a little easier
    tonered[QUOTED] likes this.
  17. Mar 13, 2021 at 12:51 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
  18. Jan 29, 2022 at 8:07 AM
    WGyde91
    WGyde91 Member
    Wes
    2016 SR utility 4x4
    Rough country level Spyder OEM fog 3” total stance
    bout a year late but if your getting into it again, push down the little white tab on the narrow section of the clip then pull the fat section off.
