How to remove the coolant reservoir bottle?
Discussion in '1st Gen. Tacomas (1995-2004)' started by EdFlecko, Feb 29, 2016.
  1. Feb 29, 2016 at 1:54 PM
    EdFlecko
    EdFlecko [OP] Well-Known Member
    Ed
    Sacramento, California
    I have a 2004 Tacoma 2WD with the 2.4 motor.
    I'm going to change my coolant and would like to remove and clean the coolant reservoir bottle, but I'm not sure how to remove it?
    I don't see any bolts that hold it in and it feels like it probably (somehow) snaps in place?
    Does anyone know how to remove this or can you point me toward some documentation on how to do so?
    Thank you,
    Ed
  2. Feb 29, 2016 at 2:01 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Yep, snaps in. You will have to remove battery hold down. Remove hose and pull straight up. It will have some resistance. Be prepared so you don't smack yourself in the face.
  3. Feb 29, 2016 at 2:31 PM
    EdFlecko
    Ed
    Or splash coolant in your face and eyes, right?
    Thank you!
    Ed
  4. Nov 23, 2020 at 1:22 PM
    Kimber
    Kimber New Member
    Kimber
    2002 Toyota Tacoma
    My coolant reservoir comes out really easily on my 2002 Tacoma. No splashing if it isn't really full. You just pull up on it. If it does resist, you can always suck out some of the coolant with a turkey baster.
    koditten and Taco critter like this.
  5. Nov 23, 2020 at 5:01 PM
    latchlock8111
    latchlock8111 Well-Known Member
    ... before you "pull" it up to slide out spray a little silicone in/on the slots. Work it up a bit then push it back down. Repeat ... going a bit further each time.
