How to remove the exhaust manifold studs?
Discussion in 'Technical Chat' started by FinnJ, Jun 29, 2017.
  1. Nov 22, 2018 at 7:48 AM
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    I don’t know if it’s available in your area, but you might try a product from Kano Labs in Tennessee
    http://www.kanolabs.com/
    The product is called KROIL, an excellent penetrating oil, worth a try, I’ve had a lot of success with it.
    MTopp likes this.
  2. May 17, 2021 at 6:04 PM
    Daves300
    Daves300 TTC#0333
    Texas
    2007 FJ
    I did it today and it works:bananadance:
  3. May 17, 2021 at 7:09 PM
    Chatt69chgr
    Chatt69chgr Well-Known Member
    2017 Quicksand Tacoma TRD 4X4 OFFROAD
    None
    That beeswax trick is something I learned from a mechanic that has had to remove broken studs in engine cylinder heads. He told me that it works every time. Glad to hear that you had success using that technique.
    Daves300 likes this.
  4. May 17, 2021 at 7:21 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Make up some Ed's Red. If not Kroil will work but you need to allow time for it to penetrate. I think you are a wee bit too far away to use my induction heater.
  5. May 18, 2021 at 8:11 AM
    MR5X5
    MR5X5 Well-Known Member
    Beeswax is great. Multiple days of PB Blaster Soaking is fine. Putting heat to the stud should be to help whatever penetrate you use wick. Be sure to let it cool before you give a twist. Hot stud + cold block = tighter. Really no effective way to heat the block beyond the stud. Too much mass....
  6. Dec 17, 2023 at 11:49 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Found this older thread because my studs look pretty crusty too after 17 years (2007 truck). Not looking forward to getting them out.
    Anybody replaced these studs/nuts with bolts? Or is there a clearance issue?
  7. Dec 17, 2023 at 11:52 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I don't see why bolts wouldn't work. Just get a good length and maybe some washers. The bolt head shouldn't be to much wider than the nuts that are coming off.
    Look for a nice shouldered bolt (technically called a cap screw I believe)
  8. Dec 17, 2023 at 12:16 PM
    TireFire
    Olympic Peninsula
    That’s what I thought. Some nice SS cap screws will be much cheaper than the $120+ for the ARP studs/nuts everyone buys. And makes header install easier
  9. Jan 11, 2024 at 4:30 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Header bolts are generally a bad idea with aluminum heads. Too much risk of threads pulling.
  10. Jan 11, 2024 at 9:18 AM
    TireFire
    Olympic Peninsula
    Copper or nickel anti-seize. LS/LT motors use bolts from the factory.
    Plus, my steel studs already have to come out of the aluminum heads.
  11. Jan 28, 2024 at 5:08 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Sounds like you have a plan……best of luck
  12. Jan 28, 2024 at 5:11 PM
    Bishop84
    Bishop84 Well-Known Member
    I've done lots of rusty headers, I dont know if butane or propane is enough, I get them stupid hot before touching them with acetylene.
