How to remove the master power window switch circuit board
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CoreyF, Jul 4, 2023.
  1. Jul 4, 2023 at 3:55 AM
    CoreyF
    CoreyF [OP] Corey
    Suffolk, VA
    2013 Tacoma 4WD SR5 Access Cab V6 Automatic
    2013 Access cab, 2-door 4x4, 6 cylinder.
    I need to remove the circuit board from the master power window switch, but I can only lift up one end of the board and the other end won't pry out. The actuator arms need to be realigned to insert correctly into the power button grooves that are attached to the buttons themselves. Is the one end that prevents me from removing the circuit board glued in or attached to the underside of the power buttons or something? I can't pry out the board so I can align the button levers into the actuator "arms" on the circuit board.
