How to remove the rear break cable
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tsean, Nov 1, 2023.
  1. Nov 1, 2023 at 9:04 AM
    Tsean
    Tsean [OP] Well-Known Member
    Tsean
    Here is the some of the pics what I’m trying to do here to remove the cable and add icon leaf 1.5 inch lift is anyone can help me out for some steps how to remove it
    And also this bolts turn itself does not won’t come out can I cut it off if I need too.
    bushing is going to be pain hard stuck I have no clue how to get it off so tough and tried almost anything only thing came out is nuts itself won’t coming out
    thx guys so sorry for the bothering you all…
  2. Nov 1, 2023 at 9:19 AM
    Old metals
    Old metals Well-Known Member
    02 x-cab 4x4 2.7 2018 TRD Sport 4x4 3.5
    Original
    if you can get vice grips on the head side of the pin and rotate it back and forth a little at a time that usually frees them up. Try something like PB Blaster on the bolt. Just let soak then see what happens.
    Tsean[OP] likes this.
  3. Nov 1, 2023 at 9:36 AM
    Tsean
    Tsean
    Copy will do it now fingers crossed.
  4. Nov 1, 2023 at 10:55 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Every time I ever changed springs I ended up Cutting the hanger bolt off at both sides enough to pry the hanger apart and pry the spring out.
    I have never been able to remove the bolt.
    good luck!
    Tsean[QUOTED][OP] likes this.
  5. Nov 1, 2023 at 11:07 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    This is the scariest thread I have seen in awhile.
  6. Nov 1, 2023 at 11:38 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Dude. I don't know where to start here. But please stop and do some deep research before you do this.
    Before you remove the wheels you needed to have broken loose all the bolts you needed to remove (including the front spring hanger bolts). You almost certainly need a good air impact to remove the forward spring bolts. PB Blaster and Impact is the only way that's coming out unless you have to cut it. You also NEED 6-sided sockets. It looks like you're beginning to round the head of the bolt already.
    The fact that you're trying to remove the center pin without any understanding of what it's holding back is plain scary. You need to clamp the leaf pack together before you try to loosen that center pin. If you don't, the individual leaf springs will push apart at force.
    I hope your AAL came with new center pins, and that you got new u bolts.
    Hopefully you have the proper well supported jackstands below the frame rails and the jack below the axle housing itself. You have to be very careful to not over extend the rear brake line or the other wire loom (locker, abs, etc) going from the frame to the rear axle.
    That brick and piece of metal is not well supported, and just flat out dangerous.
    You also need to use a ratchet strap to make sure the axle doesn't move aft when it's free floating. You have to make sure the rear drive shaft does not separate at the slip yoke.
    When you go to tighten the new u bolts. I would suggest NOT tightening to full torque spec (if full toque is 100, go to 50-60) until you have taken it for a short low speed test drive, and you're sure that everything is in solid working order.
    As a general note- The front hanger, shackles, and u bolts, should only be torqued once the truck is on the wheels sitting normally on the ground. If your torque things when the truck is up in the air, you're gonna have a bad day.
    Bivouac and Kwikvette like this.
  7. Nov 1, 2023 at 11:47 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    This.
    Basically follow the same rules for removal/replacement of a leaf pack.
    It's stupid simple to do on your own, but carelessness can make this small job a dangerous one real quick.
  8. Nov 1, 2023 at 12:21 PM
    Tsean
    Tsean
    Ohh man see thank you so much seems like it’s so hard to complete this job however will apply above the infos as you said
  9. Nov 1, 2023 at 12:22 PM
    Tsean
    Tsean
    Ok I see you point I will be extra careful
  10. Nov 1, 2023 at 1:07 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I don't know where you are located, but I really suggest seeing if there is a regional sub forum with active members in your area, and finding someone local with some more experience to help you get going through you projects. There are a lot of things that just take time to learn, and while you have certainly shown you're willing to tackle this stuff DIY, I think you would really benefit from going to a few wrench-a-tons / mod-days in your area and getting connected with local guys also working on their trucks.
  11. Nov 1, 2023 at 1:26 PM
    Tsean
    Tsean
    Ok I got you
  12. Nov 1, 2023 at 1:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Region you're in would say more about the condition your truck's in too
    I see what looks like a rust-coated leaf pack, so you might find yourself cutting your leaf pack bolts off
  13. Nov 1, 2023 at 3:23 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  14. Nov 2, 2023 at 8:14 AM
    Tsean
    Tsean
    Copy that I got this truck from Va state
  15. Nov 2, 2023 at 8:15 AM
    Tsean
    Tsean
  16. Nov 2, 2023 at 8:15 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Wish you the best of luck
    Us Californians don't know what rust is :bananadead:
  17. Nov 2, 2023 at 8:18 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I was thinking a little about this- If you're installing an 1.5" Add a leaf- why are you trying to remove the forward spring hanger bolt? You don't need to touch the main leaf spring to install an AAL.
    Tsean[OP], Kwikvette and Gen1andDone like this.
  18. Nov 2, 2023 at 9:21 AM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    I was just about to post the same thing.
  19. Nov 2, 2023 at 4:08 PM
    Tsean
    Tsean
    Very good question wow didn’t realize it
