How to repair broken headlight tab (not a Tacoma)
Discussion in 'Lighting' started by SR-71A, May 16, 2024.
  1. May 16, 2024 at 7:26 AM
    SR-71A
    SR-71A [OP] Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Edit: See below. Ended up using JB weld quick to repair the tabs
    This is for my daily driver, not the Tacoma. Figured Id post on here though as there's lots of knowledgeable folks.
    Need a new headlight assembly due to a minor hit and run that cracked the lens. (Luckily no other damage) My state will not pass broken lenses during inspection, even though all the bulbs still work... :mad:
    Anyway. Typical fleabay find here. Showed up with a broken mounting tab as you can see. What would people suggest to fix that? My first thought is an epoxy that will hold up over time. But I'm sure people have good products they can recommend for this exact application.
  2. May 16, 2024 at 7:31 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    I have used jb kwikweld on cracked headlight housings in the past
    YF_Ryan likes this.
  3. May 16, 2024 at 7:44 AM
    SR-71A
    Zack
    Southern Maine
    Honestly that was my first thought :D
    Didn't know if there was something better to consider
  4. May 16, 2024 at 9:18 AM
    SR-71A
    Zack
    Southern Maine
    Given I need to get this fixed ASAP I might just send it with some JB quick
  5. May 16, 2024 at 9:30 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Used JB a broken headlight tab after having success on taillight tabs. The taillight tabs lasted a few years before I added more JB. Be liberal so the load can spread out. I shoulda done that in the first place.
    SR-71A[OP] likes this.
  6. May 17, 2024 at 8:04 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    My son used one of the cheap plastic welders from Amazon that uses the S shaped wires to fix a headlight tab on his Ram Power Wagon. He siad it worked great. The machine heats the little wires and they melt into the plastic "welding" them back together. I have one and have used it for some DIY stuff around the house. They work great. You can pick them up on Amazon for around $20. Mine uses a Dewalt 20v battery for power. Here's the one I have. https://www.amazon.com/dp/B0C4XJZ92D
    deanosaurus likes this.
  7. May 17, 2024 at 8:06 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    I second plastic welding it. Shit I’ve even used a solder iron to use some scrap plastic of similar composition to “weld” some plastic pieces together and the result ends up quite strong albeit ugly. You could then run some jbweld for plastics over that.
    Rocketball likes this.
  8. May 17, 2024 at 8:09 AM
    Rocketball
    Scott
    Westminster, MD
    I've also used a standard soldering iron as well, and cut some small pieces of metal window screen and melted it into the plastic. That's had limited sucess, but it worked, sort of.... And surprisingly enough the soldering iron didn't get all gummed up with the melted plastic. It was VERY clean when I was done.
  9. May 17, 2024 at 8:10 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    If you can use a splint along with the epoxy, it’ll help a lot.
    A tab of aluminum, steel, a compatible plastic, glass fiber, or even a popsicle stick embedded in the epoxy spanning the patch will help spread the load and give the repair a better chance.
  10. May 17, 2024 at 8:20 AM
    SR-71A
    Zack
    Southern Maine
    Thats a good idea to use some sort of 'splint' material in the epoxy
  11. May 17, 2024 at 9:48 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    JB Weld Plastic Bond, works great!
  12. May 20, 2024 at 5:04 AM
    SR-71A
    Zack
    Southern Maine
    Thanks fellas. Went for some good ol JB quick with a tiny piece of metal to brace the crack.
    deanosaurus, Rocketball and uurx like this.
  13. May 20, 2024 at 5:27 AM
    Goldielocks
    Goldielocks Well-Known Member
    You did a GREAT job repairing that broken tab! It's fortunate that the broken piece came with your e-bay headlamp.
  14. May 22, 2024 at 6:33 AM
    SR-71A
    Zack
    Southern Maine
    WELL.. Broke another tab / bracket thing last night trying to install this damn thing. Fucking German plastic - look at it wrong and it turns to dust
  15. May 29, 2024 at 6:43 PM
    Captqc
    Tigard, OR
    I used a heat gun to soften the plastic tabs on my headlights as I was installing them so they wouldn’t break.
  16. May 29, 2024 at 8:03 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    At least you know how to fix them.
    SR-71A[QUOTED][OP] likes this.
  17. May 30, 2024 at 6:10 AM
    SR-71A
    Zack
    Southern Maine
    Been about a week with no issues. I think the JB will be stronger than the 20 year old german plastic
