How To: Repair/Replace door panel inserts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GHOST SHIP, Sep 23, 2018.
  1. Jan 18, 2023 at 10:24 PM
    GHOST SHIP
    GHOST SHIP [OP] hates you.
    GHOST
    Unlikely. Fiberglass doesn’t particularly like to adhere directly to plastic. What made my original repair hold was how I shaped the fiberglass around the multiple contours of the insert and even wrapped around an edge or two. This sort of encapsulated the arm rest in a way that even if it did delaminate, the fiberglass was structurally sound on its own. You could try plastic welding heavily but even then you’ll probably want to add some filler material to strengthen the repair. An old trick I learned to plastic welding is to trim off some small slivers from another area of the original panel that won’t be seen or compromise the structure. That way you have the same plastic compound and color to add to your repair.
  2. Feb 18, 2023 at 5:40 PM
    MAC_95820
    MAC_95820 Member
    San Diego
    2010 PrRunner 4.0L
    Thanks for the feedback! Hoping to get this tackled soon.
