How to replace license plate bulb housing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RmikeD, Jun 8, 2019.
  1. Jun 8, 2019 at 7:44 AM
    RmikeD
    RmikeD [OP] Well-Known Member
    2016 Barcelona Red TRD OR DC V6 Auto, std bed, factory mud guards and bed mat
    Tow package, Factory Tonneau Cover
    The bulb on passenger side shorted out because the lens was full of water. I removed the bulb holder but realize I need to replace housing. My 2016 TRDOR does not have an external screw on bumper inlet containing the bulb housing. Does anyone know how to remove the housing? Also, I twisted the bulb holder counterclockwise to remove but can’t seem to get holder depressed enough to reinsert. I see the 3 tabs on socket with one being wider than other 2. Any tips on reseating the bulb holder. Very tight fit with trailer hitch. Wondering if I need to remove trailer hitch to get hand on bulb holder or to depress the 2 tabs on the housing which may then allow it to be pushed out thru the bumper opening. Thanks in advance.
  2. Jun 8, 2019 at 10:26 AM
    RmikeD
    I got it figured out. I depressed the tabs and pushed housing out thru bumper. I was expecting the raised black rubber edge around the hole to be part of housing, which it is not. Glad I did not try prying under edge of black trim with flat blade as I would have mangled up bumper cover. The tight fit under bumper scratched up back of thumb pretty bad. I inserted the bulb housing with harness pulled thru bumper hole. Took a fair amount of Force depressing gasket to get the 3 ears inserted in their slots. I was not able to do it from under bumper. Especially with trailer hitch
  3. Jun 8, 2019 at 6:59 PM
    Jim1946
    Jim1946 2020 TRD Sport 4X4
    San Francisco Bay Area
    2020 TRD Sport 4X4
    I believe there is a TSB for leaking license plate bulbs.
    CusterFan likes this.
