How to Replace studs on Wheel spacers
Discussion in '1st Gen. Tacomas (1995-2004)' started by dreyes123, Feb 20, 2012.
  1. Feb 20, 2012 at 7:31 PM
    dreyes123
    dreyes123 [OP] Member
    david
    ga
    tacoma
    nitto mud grapplers
    Hello i have a set of wheel spacers and im trying to replace the studs, idk if i can just hammer it out and then just hammer the other one in, or if there is any kind of glue or anything i put on it
  2. Feb 20, 2012 at 7:56 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Do it like you would do a wheel stud on your hub and hammer the old one out the id probably put osme loctite on the new one and just stick it in as far as it will go (thats what she said :rofl: ) and find a socket that is shorter than the amount of thread showing on the new stud and start the nut/lug untill it draws the new stud up into the spacer... Hopefully that makes a little sence
  3. Feb 20, 2012 at 8:01 PM
    dreyes123
    david
    ga
    tacoma
    nitto mud grapplers
    thanks man i will try it tommorow
  4. Feb 20, 2012 at 8:14 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Sure thing man, thats how we put new studs into the beamers and benz's at work so i would think it would be about the same idea for the wheel spacers
  5. Apr 25, 2021 at 3:55 PM
    Popeye65
    Popeye65 New Member
    Ken
    Where did you find the replacement studs?
