How to Replace Tailgate?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MShadowz, Aug 12, 2010.
  1. Aug 12, 2010 at 1:13 PM
    MShadowz
    MShadowz [OP] New Member
    Rico
    I have an 02 Regular cab V4 Tacoma. I'm not sure as to what parts I need to replace the entire Tailgate. It was in a wreck before I bought it, therefore did not include the original tailgate upon purchase.
    Here is what I have so far:
    -Tailgate Frame
    -The two metal support wires
    I'm pretty clueless as to what else I need to have a working tailgate. Please help me out. Thanks.
  2. Aug 12, 2010 at 1:18 PM
    8th sin
    8th sin Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    This is for a second gen but it might help...
    tailgate shell (metal frame)
    tailgate inner panel (inner plastic panel)
    tailgate handle
    L/R tailgate latches
    L/R latch strikers (rods connecting handle to latches)
    tailgate protector (plastic across the top...1st gen's may not have this)
    L/R hinges
    L/R cables
  3. Aug 12, 2010 at 1:29 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    its an I4 not a V4 ;)
  4. Aug 12, 2010 at 2:28 PM
    MShadowz
    Rico
    Hey, thanks for the response! I'm having trouble finding the rest of the parts... Does anyone know where I can order them online?
  5. Aug 12, 2010 at 2:28 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    check at a local junkyard,ya might luck out and find one same color as yours. youd be able to get everything at once that way.
  6. Aug 12, 2010 at 2:34 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    For an aftermarket one, it only comes with the main frame. You'll need the two hinges that attach to the body, the handle to open the tailgate, the left and right latches, the access cover to the handle, and of course all screws, in addition to your support wires. Also, you'll also need to get it painted.
    I'm really not sure if you can get the whole tailgate assembly from the dealer. You might be able to.
    Junk yards really are your best bet though.
  7. Aug 12, 2010 at 2:37 PM
    81shark
    81shark Well-Known Member
    you'd think a junkyard would have a complete tailgate
  8. Aug 12, 2010 at 2:47 PM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    www.toyotapartzone.com or www.toyotapartsales.com should have them if you dont want to visit the dealer.
  9. Aug 12, 2010 at 5:09 PM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    Trouble with junkyards, is tailgates there are usually .....JUNK!
    Although if OP has a decent shell, a junkyard gate (as long as all hardware is there) will work.
  10. Aug 13, 2010 at 6:46 AM
    8th sin
    Tampa, FL
    2015 DCLB 4x4 Sport
    The dealer will sell you a complete tailgate, but they have to order all the component parts and will charge you to assemble and paint.
    I'd get a new frame, have it painted and get the rest of the components from a junkyard. Basically swap the new frame onto the old tailgate. That way you can be relatively sure you have everything.
