How to replace the studs for the top plate spacer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MxRacer190, Feb 3, 2012.
  1. Feb 3, 2012 at 1:54 PM
    MxRacer190
    MxRacer190 [OP] Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    How do I get these original studs out? I've already taken apart the other strut, and beat on the studs with a hammer, but they won't budge. . . I put it in the freezer for a min to see if it will loosen up a little. Am I missing something? Lol. HALLLLLP
    little info: I'm installing the 1/2" OME trim package.
  2. Feb 3, 2012 at 2:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They need to be pressed out.
  3. Feb 3, 2012 at 2:06 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    what kind of press? and would a local store have one?
  4. Feb 3, 2012 at 2:07 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    not likely you'll need a pretty heavy duty press 6-8 tons should do the trick
  5. Feb 3, 2012 at 2:59 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    do you know if oreily's will press them, or will I need to find an actual shop?
  6. Feb 3, 2012 at 3:01 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    i have no idea what orileys is capable of doing... i would take them to a real shop and pay 20 bucks to have them pressed out and new ones pressed in
  7. Feb 3, 2012 at 3:06 PM
    cintocrunch
    cintocrunch Special Substitute Guest Member
    MD
    2012 DCSB TRD Sport MGM 6MT
    Anytime fogs, Leer Tonneau
    I had to do the same thing on my Pathfinder...a hammer just wouldn't budge it...2 lb sledge took all 6 studs out in a few swings each...
  8. Feb 3, 2012 at 3:18 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    Ether put a socket under it or if u have a vice open it enuff for the stud to go down but support the plate 2-3 lb sledge should do it.
  9. Feb 3, 2012 at 9:13 PM
    xbarjoe
    xbarjoe Member
    Ron
    Dallas, TX
    White 2011 w/ TRD Off-Road
    Debadged, K&N, Shrockworks bolton sliders, ARB front bumper, CBI rear bumper, Bushwacker flairs (black), ASFIR engine and tranny skid plates, Light Racing UCAs
    You can use a vice to press out the studs. That's what I did on mine. Use a socket to support the plate.
  10. Feb 4, 2012 at 5:25 AM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Thanks guys! The socket trick/sledge worked! I'll post some pics later. Went and played hard last night after the install. Only scrubbed a few times! After an alignment, hopefully it doesn't scrub at all.
