How To Replace Third Gen Starter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by grubburg, Apr 10, 2020.
  1. Apr 10, 2020 at 5:43 PM
    grubburg
    grubburg [OP] Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    STEP 1: Buy Appropriate Starter
    Get OEM. As you can see from the below, there is a difference in quality and design. Notice the teeth. OEM should be $200 out the door. I tried the cheaper non-OEM China refurbished and got a nasty squeal. I had to return it and re-do the job. Don't take short cuts like my dumba$$ :frusty:
    STEP 2: Disconnect Negative Terminal Battery
    10 mm, 1 nut
    STEP 3: Remove Splash Guard Apron
    Be careful not to break the tabs
    STEP 4: Disconnect Steering Column Yoke
    12 mm, 2 bolts
    You need to disconnect this to make room for removal of starter and it's a tight squeeze
    STEP 5: Remove Heat Shield From Starter
    10 mm, 3 bolts
    STEP 6: Remove Positive Terminal Nut and Plastic Cap From Starter
    Plastic tabs
    12 mm nut
    STEP 7: Remove Negative Terminal From Starter
    12 mm nut
    STEP 8: De-Attach Wire Harness From Starter
    10 mm nut
    Pull wire harness away from entire area to make room
    STEP 9: Disconnect Electrical Harness
    There is a middle, bottom, long tab that needs to be depressed
    STEP 10: Disconnect Exhaust Bracket By Header/Cat
    3 14 mm bolts
    Remove the bottom 2, leave the top one loosened. Move the bracket out of the way to access starter mounting bolts. When re-installing these 3 bolts, note that you can only tighten the top one when the middle one is out.
    STEP 11: Disconnect Starter Mounting Bolts
    2 14 mm bolts
    A stubby ratchet arm is ESSENTIAL. Accessing the upper bolt is the crux of the job. It is very difficult to access with very little clearance, hence the need for a stubby ratchet oriented socket down and handle up.
    STEP 12: Wiggle Starter Out
    The starter comes out through the bottom, not by the exhaust and not by the wheel well. It's a game of tetris. After messing with it for some time, I recommend the following orientation and I think it's the only orientation that works. Otherwise, additional disassembly of truck or disassembly of starter is warranted. Be careful not to force it and damage suspension, brake or steering components.
    STEP 13: Install New Starter
    Reverse of above instructions.
    Note, when attempting to re assemble the steeling column and align the yoke, you may have to put a key in the ignition to give the steering wheel wiggle room to get the orientation correct.
    CrashZone, Jabes, Ebola888 and 21 others like this.
  2. Apr 10, 2020 at 5:43 PM
    grubburg
    2019 TRD OR MT
    Estimated time:
    - 40 minutes expert
    - 2 hours intermediate
    - 4 hours newbie
  3. Apr 11, 2020 at 6:04 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Very good !! It was the starter drive making the noise ??
  4. Apr 11, 2020 at 1:31 PM
    grubburg
    2019 TRD OR MT
    I have no idea. All I know is I've changed a starter on a 2nd gen and 3rd gen. They DO NOT like water.
    shotgunbilly420 and Rick111 like this.
  5. Apr 29, 2020 at 11:18 AM
    grubburg
    2019 TRD OR MT
    After a few weeks, I can say the OEM starter is 100x better than the non-OEM. It just starts faster. Look at the detail in the teeth.
    shotgunbilly420 likes this.
  6. Aug 29, 2020 at 9:03 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    nope
  7. Aug 29, 2020 at 10:11 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Great write up
    Dopplerplus likes this.
  8. Aug 29, 2020 at 10:22 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Great writeup! This is why I quit doing my own mechanical work since the 70s and 80s. Last time I replaced a starter it went like this:
    1. Remove old starter
    2. Install new starter
    They were designed for maintenance back then, now you can barely see the engine. o_O
    Arn57, HisDad, OG_Tacoma and 6 others like this.
  9. Aug 30, 2020 at 12:53 AM
    Eatmorevegtables77
    Eatmorevegtables77 Well-Known Member
    Kevin
    2016 trd offroad
    I believe you on the,they don't like water,shit you replaced this on your 2019.lol great write up with all the pictures will help a lot of people.thanks
  10. Sep 19, 2020 at 4:48 AM
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    NEVER buy chinese parts! I have RARELY had good experience with chinese parts and you can pretty much tell if they are by the poor casting quality too. And don't EVER use DNJ parts...they have U.S. flags all over their site and state they sell "japanese parts" but TRUST me they're chinese. Guys on an old 4runner forum swear by them but I used their t-belt kit for my subi, it cost as much as the aisin kit but was supposed to be "made in america"...it was obviously chinese parts. Worst part the tensioner leaked and failed at 12,000 miles (JUST out of their warranty) and I got to do a no-warranty head job and replace ALL my valves too.
    The bigger question...why did your starter fail on such a new vehicle?
  11. Sep 19, 2020 at 9:08 AM
    grubburg
    2019 TRD OR MT
    Literally drove through water one time. It submerged the starter for 15 seconds or less. Starter died a week later. I had the same experience on my 2nd gen. These trucks are not made to drive through water. Don't let the snorkel fool ya.
  12. Sep 19, 2020 at 9:09 AM
    BillsSR5
    bill
    2014 SR5
    good writeup
    grubburg[OP] likes this.
  13. Sep 19, 2020 at 9:44 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    The breathers can be extended, just like we do on the diffs. I'm looking at upgrading the 1.4kw starter to a cold spec 2.0kw from the older trucks... either way, the breather will be raised and modified to prevent the water ingress.
  14. Sep 20, 2020 at 5:57 PM
    Bcjammerx
    North East Texas
    Good to know! How deep would you say the water was? Like where did it come to on the truck? We get some flooding in these parts and having a 4x4 trd offroad I can see myself being braver than I should
    Dirk Diggler likes this.
  15. Oct 5, 2020 at 6:46 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Holy crap this is exactly what I am looking for
  16. Oct 5, 2020 at 1:14 PM
    Bcjammerx
    North East Texas
    tacomas are for dry offroading only apparently, saw another thread regarding a messed up front diff actuator because it got wet
    VeeSix and Dirk Diggler like this.
  17. Oct 5, 2020 at 1:16 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Oh yeah. When I yank the skid ill toss some dielectric in that too. Hopefully to help keep moisture out of that shit show
  18. Oct 5, 2020 at 3:12 PM
    VeeSix
    VeeSix Yotahead, Deadhead.
    Tennessee, USA
    2011 Tacoma 4x4
    2018 Tacoma - gone 2003 Tacoma - gone 1983 FJ60 - gone 1988 BJ73 - gone 1992 FJ80 - eternal
    You're saying a new Tacoma starter is $200?? I would have thought it was 3 times that.
    SR-71A likes this.
  19. Oct 8, 2020 at 7:26 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Thanks for this write up, I'm going to change my starter out this weekend. Coppinger Cove has mine ruined and clicking when starting. Damn you water....
    grubburg[OP] and Dirk Diggler like this.
  20. Oct 8, 2020 at 1:26 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    I'm waiting on mine to be delivered over the weekend
    cubie[QUOTED] likes this.
