How-to: Replace your automatic shifter indicator lamp
Discussion in '2nd Gen. Tacomas (2005-2015)' started by titus5, Dec 29, 2008.
  1. Dec 29, 2008 at 4:47 PM
    titus5
    titus5 [OP] Active Member
    Folsom, CA
    05 Double Cab 4x4 SR5
    Okay....this is an extremely easy fix and will only cost you a few dollars. No tools are needed to perform this fix. Let's go step by step...by the way this fix is for the shift selector next to your automatic shifter. If yours lights up when the headlights are on, you are good. If it does not, you have a burnt bulb (they all should light, no matter the truck's options.)
    This first step is to take the shifter knob off. Simply unscrew it.
    Now you can take off the silver colored portion of the console that contains the cup holder, pen tray, etc. (it is officially called a console upper rear panel sub-assembly.) There are six tabs that hold it down (one at each corner and one on each side in the middle.) Simply grasp this piece and pull straight up...I was able to get mine up at the front first and then everywhere else. Do not use any tools...you will scratch the plastic. Here is what it looks like from the bottom:
    Here is what is underneath that piece:
    Notice all of the dirt and grime? Clean everything while you're at it. It will never be easier than now.
    Ok, next we need to remove the "upper position indicator housing" as Toyota calls it. This is the piece that is around the shifter itself, with the shift pattern on it. There are only 4 tabs that hold it down. Toyota says you can use a screwdriver...I found that totally unnecessary and simply used my fingers. Screwdrivers have a way of breaking plastic, so why risk it. Here is a view of it removed...those U-shaped pieces are the tabs that hold it down.
    Now you can see the bulb exposed (actually the rubber bulb cover.) The plastic piece surrounding the shifter just lifts off...it's dirty so clean it. This piece is called a slide cover. Here is a picture of it before it is removed:
    And here is what it looks like removed:
    Next we will remove the bulb and it's cover. To do so simply grasp it and twist a quarter turn and it will drop down. You can see how far you need to twist by watching it from the top. The notches are clearly visible. Here is a side view of the "indicator lamp wire sub-assembly" as Toyota calls it:
    And here it is after it has been taken out of its spot:
    Notice the orange rubber cover....the dealer warned me ahead of time that this would be melted to the bulb. He was right. It was fused to the glass and not re-useable. To remove the bulb simply pull it straight out. Here is what it looks like out:
    Okay...the parts you will need and their numbers are visible in this photo...I was able to get 20% off if I bought them on Wednesday between 4 and 6 PM...maybe you can do the same:
    To install the new rubber cap on the bulb required a tiny bit of saliva...otherwise it just sticks. You can see how it might fuse together...the rubber is very thin:
    Push the new bulb into its socket, and twist and turn the socket into the console. In other words...install everything just the way it came out. Walla! A lighted shift selector! Good as new.
    Let me know if there are any questions....I hope this helps at least one person on these forums. Who knows what the dealer would charge to do this...but it is literally a 5 minute job. Very easy.
    Tankman, devkurf, TomTwo and 4 others like this.
  2. Dec 29, 2008 at 4:51 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i vote for a stickie
    TomTwo likes this.
  3. Dec 29, 2008 at 4:53 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    yup. its worthy of becoming a sticky
    TomTwo likes this.
  4. Dec 29, 2008 at 5:00 PM
    AK27
    AK27 Well-Known Member
    can you do this without the orange plastic bulb cover?
  5. Dec 29, 2008 at 5:18 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    A do it your-selfer'. Nice job.
  6. Dec 29, 2008 at 5:35 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    yes, it just wouldnt match the rest of the trucks light up display.
  7. Dec 29, 2008 at 5:59 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Great post. Probably over a hundred to get done at the dealer, and they wouldn't clean anything!
    Mast3rSkywalk3r likes this.
  8. Dec 29, 2008 at 6:07 PM
    gavonder
    gavonder She's Kickass!
    Bethel, Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    Great write up. That's good to know just so you can clean everything!
    Thanks
    GA
  9. Dec 29, 2008 at 6:09 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Very good write up, will come in handy.
  10. Dec 30, 2008 at 5:10 AM
    Don G
    Don G Old Goat
    Southern Tier New York
    "08" Tacoma Access Cab TRD Sport 4X4
    Thanks for the information!!!!:)
  11. Dec 30, 2008 at 5:45 AM
    silver6
    silver6 Member
    Frankfort, Ky
    Tacoma Double Cab 4x4 Sport
    Brand new
    Good info for those days when the seats have to come out to clean!:eek:
  12. Dec 30, 2008 at 6:43 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Im tryin to find a blue bulb for mine
    KD7YHT likes this.
  13. Dec 30, 2008 at 11:32 PM
    titus5
    Folsom, CA
    I'm glad everyone's liking the post. Just wanted to give back a little, as these forums have been helpful to me.
    BluLED likes this.
  14. Apr 21, 2009 at 1:12 PM
    Ayla Nicole
    Ayla Nicole Member
    From SoCal...stuck in Tx
    Tacoma TRD Sport 2WD in Speedway Blue
    I hate the orage display lights...Is there a way to change them all to a different color on my own? i really like blue :D
    xxNave556 likes this.
  15. Jan 1, 2010 at 11:55 AM
    woodland 01
    woodland 01 Member
    Ron
    Southern Ontario
    10 Double Cab Sport Package
    Thanks for the information. I want to install a LED light into the centre console for some extra light over this area. Thanks again. Happy New Year.
  16. Jun 19, 2010 at 6:40 AM
    Sideways
    Sideways Well-Known Member
    Maryland
    05 TRD dbl cab
    Great thread, My shifter was starting to stick so I needed to remove the console cover.
    One other point I might add about the shifter light, instead of using the rubber cover try painting the bulb (Whatever color) with a coat or 2 of spray paint, it gives the same effect as the rubber boot.
    bowyer2002 likes this.
  17. Jul 30, 2010 at 10:02 PM
    dubbedSinner
    dubbedSinner blisters
    Lowered 3/4, debadged, led tails, projector headlights with hids, billet grill, blacked out windows, painted front and rear bumper and grill shell. Inside, 4 crappy 15's, suede wrapped headliner and door panel inserts, alpine double din, few painted pieces inside, and every led is either blue or white.
    what size is this bulb? i tried looking around but had no luck
  18. Nov 28, 2010 at 7:23 PM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    ^ same question
  19. Nov 28, 2010 at 7:28 PM
    tencrawler
    tencrawler I'm a lover not an expert
    Wes
    Petaluma
    1985 Pickup 4x4 SCLB 22R 5SPD Manual
    Only 55K Original Miles in Spring of 2018
    It looks like a 194 or 168. Those are the standard dash and marker bulbs. If you don't want to buy the orange cover you can buy 194 and 168 in amber (same bulb as the stock headlight marker bulbs).
  20. Nov 28, 2010 at 7:40 PM
    BravesFan
    BravesFan The MOST Badass Offroad Truck
    Rob
    Brentwood, TN
    09 Super rock crawler
    did anyone ever find a blue bulb or led that would fit in there?
