How To: Replacing Carrier Bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJPP, Jan 27, 2013.
  1. Nov 7, 2016 at 7:26 AM
    #221
    jesseunvoas
    jesseunvoas Well-Known Member
    Jesse
    Swift Current, Sask, Canada
    08 TRD SPORT
    3" Ready Lift Super 80 Muffler AFE Stage 2 CAI Pro Dry Filter OEM Roof Rack RollBAK Tonneau Cover Cooper AT3 Tires Kakays On The Roof free candy topper
    Just a 2.75 lift bilsteins all around with the new left springs from toyota and rear blocks
  2. Nov 7, 2016 at 7:30 AM
    #222
    geoyota760
    geoyota760 Allergic to pavement
    PHOENIX, AZ
    2019 TRD OR
    5.29 Nitros Bilstein ICON Kansei BFG
    IMHO...you shouldn't have any issues, or need to install a poly drop block for the CB mount.
  3. Nov 7, 2016 at 8:24 AM
    #223
    jesseunvoas
    Jesse
    08 TRD SPORT
    do you know what thickness?
  4. Nov 7, 2016 at 8:45 AM
    #224
    geoyota760
    PHOENIX, AZ
    2019 TRD OR
    Honestly, I had to do a little "internetting" before I responded, because for my 5" lift on my previous vehicle (all suspension, arched springs and extended shocks) I used 3* shims installed between my leaf spring/axles to raise the pinion (front of the rear differential, where the drive shaft is connected via u-joint) angle.
    And, if you read this article supported by KLM Performance, you only attempt to block drop the CB in "aggressive/greater than 4-6" lift situations, where your stated 2.75" Bilstein/rear block lift doesn't really qualify.
    I only know that if you are experiencing driveline vibrations after installing a lift, the CB is but one of the many variables that you need to check/be aware of when things get stiffer and higher at all four corners.
    What year and model Tacoma (2WD/4WD?) do you have?
    I'm really curious, what "results" or "issues" are you experiencing with your lift??
    Is this your lift: Readylift 3.0"
  5. Nov 7, 2016 at 8:55 AM
    #225
    jesseunvoas
    Jesse
    08 TRD SPORT
    08 dbl long box. there was small vibes before I had the new leaf springs installed from the recall and now there is noticeable vibes at 45-60k went under the truck and checked all the u-joints couldn't feel and play only thing I noticed was there was a good amount of up and down movement on the rubber cb so that's what i've narrowed it down to..
  6. Nov 7, 2016 at 8:58 AM
    #226
    jesseunvoas
    Jesse
    08 TRD SPORT
  7. Nov 7, 2016 at 9:01 AM
    #227
    geoyota760
    PHOENIX, AZ
    2019 TRD OR
    Before you go chasing driveline stuff...make sure you have recently (last month or so) aligned your front end, and had a rotation/balance of all four wheels/tires. I still have a little vibe from 65-70 mph and have narrowed it down to my tires...BFG KO2's are out of round and Discount Tire blames it on my 1.5" wheel spacers (that I have since removed)...I call BS on that, but because it's a "modification" they are stating that the tire warranty is null & void. :frusty:
    I dropped $100 at my certified Toyota mech. to check everything, and he narrowed it down to the tires...AND said the wheel spacers won't cause a vibe/shimmy, but will amplify one if it does exist.
    Gotcha...you shouldn't need to shim your leafs/axle for this lift, BUT, if you chose to it wouldn't hurt. You don't need the CB drop kit for this lift.
    The dark art of driveline specs (IMHO) has a LOT of room for shades of grey...one thing may work on one truck, etc. etc.
    Keep checking things off the vibe list (all suspension components, ball joints, tie rod ends, tire condition, driveline condition, u-joints, u-joint grease, etc.) until you have it narrowed down.
    Be patient, and be prepared to spend a little time and $$$ figuring it out.
  8. Nov 8, 2016 at 6:27 AM
    #228
    jesseunvoas
    Jesse
    08 TRD SPORT
    yeah I need to rotate the tire and get a wheel allignment done but I did end up getting a spicer cb bearing for 28$ through work so i'll try that out to start with.
  9. Dec 12, 2016 at 2:47 PM
    #229
    MilesToEmpty
    MilesToEmpty Well-Known Member
    Charles
    Frederick Co, MD
    '13 Baja TX
    Wheelers Progressive AAL, Firestone RideRite airbags.
    Cross posting because I have a stupid vibration and a lot of the threads are having multiple options. Second gen...
    At 20mph, accelerating and decelerating I have a vibration. Feels almost like I have mud terrain tires.
    My only mod is the wheelers Progressive AAL, with factory overload removed. This was just a band-aid until I could afford Dakar's. But I'd like to get this vibration fixed.
    Not sure if I should take it to Toyota or not? Truck has 33k miles. Ive been reading all this drivetrain voodoo stuff.
  10. Dec 13, 2016 at 9:54 AM
    #230
    jesseunvoas
    Jesse
    08 TRD SPORT
    Feels like the same issue I had, bought new carrier bearing and new u-joints. Turned out it was just one u-joint.
    Lift your rear end, block truck and put in neutral then go under the truck and with the tranny in neutral you should be able to check your driveline.....Also When I re-installed the carrier bearing I ended up just rotating it since the former lower portion seemed softer than the upper portion. But give this a try before donating more money to Toyota.
  11. Jan 13, 2017 at 7:00 PM
    #231
    mblkh2o
    mblkh2o Well-Known Member
    Manny
    Chandler, AZ
    2002 Black Tacoma TRD Crew Cab
    2.5 inch Bilstein 5100 lift and 3 leaf progressive springs w/Pro Comp 69 series wheels and BFGoodrich K/O2 265/75R16's
    So would just putting a new carrier bearing in reduce a vibration I suspect is coming from my driveline? I have about 2.5 to 3 inch lift from bilstein shocks and a progressive aal with new wheels and tires(285/75r16, 16Ă—8, 4 in. BS) it started once I got the new shoes on. It only starts to vibrate after I brake about 10 mph then fully stopped. That's the only time.
  12. Jan 13, 2017 at 9:28 PM
    #232
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    When you say "shoes" are you referring to tires or brake shoes?
  13. Jan 14, 2017 at 5:31 AM
    #233
    mblkh2o
    Manny
    Chandler, AZ
    My bad I meant my new tires and rims
  14. Jan 14, 2017 at 6:13 AM
    #234
    mechanicjon
    Jon
    Scottsdale Arizona
    Try rotating tires front to rear. See if it changes. What brand tire and wheel?
  15. Jan 14, 2017 at 6:29 AM
    #235
    mblkh2o
    Manny
    Chandler, AZ
    I have the Mickey Thompson baja claw and the pro comp 7069, I expected noisy tires from these but not a vibration when I brake and at low speeds, around 5 mph(forgot to mention that)
  16. Feb 20, 2017 at 10:02 AM
    #236
    tony2018
    tony2018 Well-Known Member
    Could be something binding. I was going to say get the new tires roadforced balance but if this is happening at low mph while breaking I feel that its something else.
  17. Feb 20, 2017 at 4:12 PM
    #237
    mblkh2o
    Manny
    Chandler, AZ
    Could be? But my carrier bearing looks worn too, and I put some washers to lower it and it took it away for a little while but I feel if I can replace the bearing it'll fix the problem but I gotta wait till I can afford an oem one
  18. Feb 20, 2017 at 4:55 PM
    #238
    tony2018
    Cool beans, shouldn't be too hard to do after reading the guide. Pls report back.
  19. Feb 21, 2017 at 7:07 AM
    #239
    mblkh2o
    Manny
    Chandler, AZ
    For sure buddy thanks
  20. Mar 8, 2017 at 1:58 PM
    #240
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Is this process similar for 2nd gens?
