How To: Replacing Carrier Bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJPP, Jan 27, 2013.
  1. Jun 24, 2019 at 9:35 AM
    #321
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    In the middle of removing my CB the washers fell out and I don't know where they go now. I know the large one goes with the large nut. But where does the two skinny ones go?
    Referencing step 12 in the how to. "Step 12 – Be sure that you replace the washers and nut back on in the correct order of removal."
    Clucky likes this.
  2. Jun 24, 2019 at 9:45 AM
    #322
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Opposite side of thick washer. Thick washer and towards rear of truck, 2 thin washers towards front of truck
    Clucky and Fatal_Paradox like this.
  3. Jun 24, 2019 at 9:47 AM
    #323
    Fatal_Paradox
    Bardstown, KY
    Okay so both thin washers go together on the spline coming from the front before new CB is placed on. Thanks.
  4. Jun 24, 2019 at 9:52 AM
    #324
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
  5. Jun 24, 2019 at 9:53 AM
    #325
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    I also wire brushed all the mating surfaces and the splines, but I have ocd.
  6. Jun 24, 2019 at 11:08 AM
    #326
    Fatal_Paradox
    Bardstown, KY
    I plan on doing that then hitting with brake cleaner and using grease all over everything. I'm also cleaning up and painting the mounting location for the CB and using new bolts. I may have OCD as well.
  7. Jun 24, 2019 at 11:13 AM
    #327
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Sounds like a pro job!!!
  8. Jul 4, 2019 at 12:33 PM
    #328
    Sinkalip
    Sinkalip Member
    04 DC 04 RC
    I bought the spicer bearing and like some here my old bearing slid off without a puller and the new one slid on effortlessly but is not loose. Should I put on some sleeve retainer or is it fine with just a slip fit?
  9. Jul 4, 2019 at 1:08 PM
    #329
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Slip it on, it’ll be fine. There is a proper torque procedure. Basically it’s really tight then back off to torque setting. Info might be in this thread.
  10. Jul 11, 2019 at 7:06 AM
    #330
    paulwal
    paulwal Well-Known Member
    Thanks for the tutorial. I get vibrations in the 65-70 mph range. I'm guessing a new carrier bearing will fix this. Is everyone going with OEM or is there a recommended cheaper aftermarket version?
  11. Jul 11, 2019 at 7:18 AM
    #331
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Spicer is the way to go!!
    paulwal likes this.
  12. Jul 11, 2019 at 8:44 AM
    #332
    vettehigh
    vettehigh Tacoma Tank
    Jon
    Upstate, NY
    CS_AR and GQ7227 like this.
  13. Jul 11, 2019 at 3:27 PM
    #333
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Not sure what a mechanic would charge in your area. It’s an easy job. Took me an hour max, just with hand tool and a torque wrench
  14. Jul 15, 2019 at 6:47 AM
    #334
    vettehigh
    Jon
    Upstate, NY
    Just met up with the top drivetrain guy in my area. Super cool guy, but he doesn't do work on the side because he is so busy with his family and farm. Damn, my luck. He told me to just unbolt the 4 bolts on the front and the 4 bolts on the rear (making sure I mark the spots on both front/rear) and bring the entire shaft to him and within the day he will change out my carrier bearing ($65). I think that is what he said :confused:
  15. Jul 15, 2019 at 8:03 AM
    #335
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    If youre gonna unbolt the shaft, Id just go ahead and do the job myself. Muscling those DS bolts out is half the work lol.
    vettehigh[QUOTED] likes this.
  16. Jul 17, 2019 at 11:43 AM
    #336
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    I recently had my carrier bearing replaced, along with new u-joints, straightened one drive shaft and balanced other... I took it in due to an ongoing vibration issue..
    Before doing all that, you could grab the drive shaft and move it up and down approx an half inch to inch... I was told after, by a Toyota Tech, that was normal (the play in CB)..
    After having this done, things have gotten worse in different ways.
    One of my question for you guys is, did or do any of you have play in your carrier bearing?
    One of my thoughts is if the play was or is normal, now with a less forgiving carrier bearing, it's shifting "issues" around bc it's not soaking the play up in the carrier bearing.... Hope that makes sense.
    Thoughts? Help?
    This has driven me crazy, I'm seriously considering getting another ride.
    NOBODY seems to know jack crap on how to fix this or find the real problem to start. I've taken it to multiple shops, so called specialist, NOTHING.
  17. Jul 17, 2019 at 12:18 PM
    #337
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Could be your vibration issue is in another area? Are the driveshafts properly aligned/clocked?
    How many miles on the old CB? Was the bearing rubber donut collapsed?
    Dude all can be fixed, don't give up!
  18. Jul 17, 2019 at 6:52 PM
    #338
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    Anythings possible at this point, I've even started wondering if maybe I have a troll hanging and banging around under there shaking things up.
    It had about 140,000 on it when changed out. There wasn't any visible collapse like torn apart or whatever, you could just move the drive shaft up and down a bit...
    I've been trying not to give up, but this is like a phantom troll on meth under my truck, with the best ghosting skills I've seen (or haven't) in a while.
  19. Jul 17, 2019 at 7:59 PM
    #339
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    140k is ok to change out the CB. Check driveshaft for proper alignment/ clocking.
  20. Jul 17, 2019 at 8:13 PM
    #340
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    So I changed out the carrier bearing from IEDSC poly one and it was all good.... for a while.
    It turns out that the 3rd member u-joint sympathetically decided to fail and squeak something fierce.
    After marking the driveshaft front and back, I attempted to remove the u-joint and it takes a BFH and some sockets you don't want and a few scrap pieces of 2x4.
    Here was the result:
    and the compar-o
    Not saying this is your issue but its a possibility ...
