How To: Replacing Carrier Bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJPP, Jan 27, 2013.
  1. Sep 25, 2013 at 5:57 AM
    #41
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    2020 DC Off-Road MT
    What are the symptoms of a bad center/carrier bearing? I've begun noticing an odd grinding/rubbing noise as I let off the gas pedal which seems like a drive shaft/u-joint problem since the load is being removed/added. I also have a vibration between 55-70 mph.
  2. Oct 3, 2013 at 12:06 PM
    #42
    ChrisTRD1
    ChrisTRD1 Member
    Oregon
    99 4x4 SR5 TRD
    Bilstein 5100s OME 551 Alcan 5-leaf
  3. Oct 17, 2013 at 1:58 PM
    #43
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    To anyone that installed a Dorman carrier bearing, which direction to the tabs face, front or rear or does it not matter?
    EDIT: Nvm, it will only install one way. It looks like it can go the other way but in reality, it can not.
  4. Oct 20, 2013 at 7:39 AM
    #44
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
  5. Oct 20, 2013 at 8:34 AM
    #45
    Inverno4
    Baltimore, MD
    2020 DC Off-Road MT
    I bought a $30 from Amazon, DEA brand. It fixed my vibration fully but the bearing is whistling after 2 days.
  6. Oct 20, 2013 at 12:51 PM
    #46
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    I'm confused, in your PM you said there was still some vibes. Maybe I misunderstood.
  7. Oct 20, 2013 at 1:32 PM
    #47
    Inverno4
    Baltimore, MD
    2020 DC Off-Road MT
    It fixed my one as I let off the gas pedal which I was afraid of it being pinion bearing or larger issue. I do still have a slight vibration but nothing like before. The new carrier bearing is squealing already.
  8. Oct 20, 2013 at 1:59 PM
    #48
    Dirty Pool
    99 XCAB V6 MT TRD
    Cool, sort of.
    Just a thought, I have witnessed the center ball in a DC joint start to squeal after flopping around during a CB/u-joint change and the other way around too (stopped squealing). Put a shot of grease in that center ball zerk, just for the heck of it and apply a little discount to my PM reply.
  9. Oct 20, 2013 at 2:00 PM
    #49
    ChrisTRD1
    ChrisTRD1 Member
    Oregon
    99 4x4 SR5 TRD
    I have 20k miles on this bearing so far, no problems at all
  10. Oct 22, 2013 at 9:23 PM
    #50
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    When you guys replace the carrier bearing, you'll absolutely want to change the flange nut too.
    Heres the part you need.
    MacGyvR and geoyota760 like this.
  11. Oct 23, 2013 at 5:39 AM
    #51
    Pugga
    Massachusetts
    Why do you say we'll absolutely want to replace it? I re-used mine, no issues whatsoever. :notsure:
  12. Oct 23, 2013 at 7:31 AM
    #52
    Alderleet
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I took a look at the upper lip of that bolt. It's tapered inward. As you thread it on, it stretches the staked end out. It's a stronger hold.
    Reusing a stretched out nut is your call...
    geoyota760 likes this.
  13. Oct 23, 2013 at 7:37 AM
    #53
    Pugga
    Massachusetts
    So you can't thread the new bolt on by hand?
  14. Oct 23, 2013 at 8:28 AM
    #54
    Alderleet
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    You can, to a point. You get about 6 rotations in, and it binds.
    I talked with one of my buddies that's a tech at the stealership. He says they use the old nut to reseat the bearing (torqued 134ft/lbs, iirc), then they pull it back off, shit can the old nut, and install and torque the new one to 51 ft /lbs and stake it.
  15. Oct 23, 2013 at 8:40 AM
    #55
    Pugga
    Massachusetts
    That's what I was looking for. Well shit... I'm not taking that whole f-in thing apart again to replace the nut, I'll keep an eye on it. Good tip, should be in the OP so people know to buy that nut along with the bearing.
    GreggieAtTheBat likes this.
  16. Oct 24, 2013 at 7:39 AM
    #56
    Nic914AZ
    Nic914AZ Well-Known Member
    Nic
    Tempe, AZ
    02 White Prerunner
    None
    If you stake it.... How could the old nut ever come off....
    I'm not concerned but if I did it again, maybe I would use a new nut if they don't charge 20 bucks for it.
  17. Oct 25, 2013 at 7:10 AM
    #57
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Agreed! After changing my carrier bearing I agree this is a good idea, I didn't change mine and have no intention of going back in to change it but if I had known it was this type of nut & "staked" beforehand I would have changed it. Highly recommend anyone changing their carrier bearing order this nut too!
  18. Oct 25, 2013 at 1:23 PM
    #58
    Inverno4
    Baltimore, MD
    2020 DC Off-Road MT
    Alderleet, any chance you checked the size of that nut?
  19. Oct 25, 2013 at 1:31 PM
    #59
    Alderleet
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Not yet. I'm heading to the shop in 2 hours, so i'll have an update for you.
  20. Oct 25, 2013 at 8:18 PM
    #60
    Alderleet
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    1.5mm threads.
