How To: Replacing Carrier Bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJPP, Jan 27, 2013.
  1. Nov 15, 2013 at 2:59 PM
    #61
    Robert Alexander
    Robert Alexander Member
    Denver, Colorado
    2002 Tacoma TRD Extracab 4wd
    Anyone know the torque spec for the two 14 mm bolts that hold the carrier bearing to the body?
    Is there any procedure for aligning the carrier bearing and or pre loading it?
    Mine was off angle and I don't want to put the new one that way.
    Thanks
  2. Nov 15, 2013 at 4:08 PM
    #62
    02coma
    02coma Well-Known Member
    la puente
    02 dc
    27ft lb
  3. Nov 22, 2013 at 5:33 PM
    #63
    quag600
    quag600 Active Member
    03 Xtra cab Mystic Gold
    DEBADGED
    Cool, I'm doing mine soon. Just got a Timken carrier and 3 new moog ujoints. Gonna replace them all.
    Nice write up, thanks :)
  4. Nov 22, 2013 at 5:37 PM
    #64
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I hope you have better luck with the Moog u-joints than I did. I bought 3, 1 didn't fit, the second fits but is a little tighter than I'd ideally like it to be and I didn't even try the third. All in all, I bought 3 u-joints and only replaced one joint.
  5. Apr 8, 2014 at 7:56 PM
    #65
    NM Taco
    NM Taco New Member
    Tim
    Santa Fe
    '01 4x4 Limited TRD
    Just purchased an '01 that has 113k on it and seems to have excessive play in the center bearing. I do have a (rear?) vibration between 60 and 70 mph and the newer-looking BFG ATs are cupping already. My rear leafs look pretty tired and I'm planning to replace them pretty soon too since I'm experiencing unacceptable axle wrap. Would poor rear leafs cause premature center bearing wear with the axle wrap I'm experiencing? If so, I'll hold off on the driveshaft work until the new leafs are installed.
  6. Apr 9, 2014 at 4:42 PM
    #66
    Robert Alexander
    Denver, Colorado
    Is your vibration on accel or deaccel, does it go away with the clutch in?
    be sure to check you rear ujoint first. disconnect the drive shaft from the rear diff and check it for play. You will not get much if any play when it is connected. I replaced my carrier bearing and it was more the rear u joint that was the problem. Oh make sure to make some alignment marks before you disconnect the drive shaft.
    Hope that helps.
  7. Apr 10, 2014 at 11:24 PM
    #67
    NM Taco
    NM Taco New Member
    Tim
    Santa Fe
    '01 4x4 Limited TRD
    It's an auto but I bumped it into N at about 65 and it had no affect. Still had vibration and it doesn't matter if I'm accell/decell/constant. Grease everything tomorrow and see if that helps. Thanks for the tips.
  8. Jun 1, 2014 at 6:10 PM
    #68
    HIJAK
    HIJAK Well-Known Member
    Gabriel
    Albuquerque
    01 4x4 DC Tacoma SR5
    3" Toytec, 33" Wranglers, Addicted offroad plate bumper, custom rock sliders, in bed spare tire carrier, sotoshi grill, 4" LEDs and LED inner fender well lights
    I'm wraith for my bearing to arrive and I will be using this write up for guidance. Thanks!
  9. Jul 3, 2014 at 11:36 AM
    #69
    elkhunter358
    elkhunter358 Member
    Steven
    AZ
    01 4x4 trd 2.5'' lift step side
    danahoe coil over 2.5-3'' 2'' leave springs in back diff breather air aid intake vinyl flooring bed liner in bed and side panels turn signal mod
    Ive got vibes rolling around 65+/-. My only difference is that it is more pronounced when the load is on the left (when I swerve right). And when I swerve left the vibes deminish. Led me to believe its a wheel bearing, so I replaced, and still vibes continue. So I replaced the left CV axle, and still the vibes continue.
    Could this be where my vibes are coming from? Would I expirence for vibes when the Left side of the truck is loaded and less vibes when its not?
    Thanks for your help.
    01 4x4 205k miles
  10. Jul 11, 2014 at 6:07 PM
    #70
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
  11. Jul 11, 2014 at 6:43 PM
    #71
    Pugga
    Massachusetts
  12. Jul 11, 2014 at 7:13 PM
    #72
    Logger
    Sam
    Ok got it. TBeers made it sound like there's another thing to mark aside from what the pics show. I decided to do it myself, especially after the shop I talked to said they don't normally worry about torquing and re-torquing to "set" the bearing.
  13. Jul 21, 2014 at 5:23 PM
    #73
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Rock Auto has a DORMAN and SKF bearing; the SKF is nearly 3x as expensive. Any reason to go SKF over DORMAN?
  14. Jul 21, 2014 at 6:58 PM
    #74
    Pugga
    Massachusetts
    I just responded to your other thread. Not sure what brand OEM is but I wouldn't go with Dorman. I got an OEM bearing through Camelback Toyota for just over $150.
  15. Jul 30, 2014 at 5:24 PM
    #75
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
  16. Sep 10, 2014 at 7:13 PM
    #76
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    So I'm in the middle of this and the fange infront of the carrier bearing isn't coming off. Nut is off washer is off. Its like it is seized or am I missing something.
  17. Sep 10, 2014 at 7:15 PM
    #77
    Pugga
    Massachusetts
    Mine took quite a few hits from a rubber mallet to free up. It doesn't just pull off.
  18. Sep 10, 2014 at 7:19 PM
    #78
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    ok cool. I have been sitting here watching videos to make sure its not got a clip anywhere I'm not seeing.
  19. Sep 10, 2014 at 7:25 PM
    #79
    Pugga
    Massachusetts
    Nope, get out the rubber mallet and don't be shy with it. Mine took quite a bit of persuasion to finally free up.
  20. Sep 10, 2014 at 9:37 PM
    #80
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Yeah that worked. But I gotta get the cut off wheel out and cut a stubborn u joint that won't come out.
