How To: Replacing Carrier Bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJPP, Jan 27, 2013.
  1. Dec 15, 2014 at 10:10 PM
    #101
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I'm ready to change mine again:(, I always hear it
  2. May 27, 2015 at 4:02 PM
    #102
    Tucker771
    Tucker771 Tacoma Beast
    Tucker
    Raleigh, NC
    2004 Tacoma Doublecab 4x4 TRD
    Gray wire mod, 4" coil lift, 2" block lift+2" AAL, rear air bags, re-located trailer wiring plugs, trail gear front bumper, kicker sound w/pioneer in-dash, 8" kicker sub, airaid MIT kit, trail gear rock sliders, arrow antenna, blacked out grille, HID kit, Smittybilt 8k winch, extended brake lines, LED overhead lighting, LED turn signals, Explorer Rock Lights, removable doors, Re-wired 4x4, Roof Rack
    Should there be any play in the bearing? I can wiggle mine around...
  3. Jun 1, 2015 at 8:20 AM
    #103
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Not in the bearing itself but the rubber around the bearing is soft and allows you to wiggle it. That movement was the cause of some of my vibration. The new ones still allow some movement but the rubber definitely allows more play with age.
  4. Jul 2, 2015 at 3:35 PM
    #104
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    For those of you with a worn out carrier, don't let it go too long. I did and paid over $330 to have it fixed. The rubber grommet on my bearing was worn out for so long, not only did I need that changed but I also needed my drive shaft straightened and rebalanced. Solved a lot of issues for me I assumed were the transmission.
  5. Jul 18, 2015 at 2:32 PM
    #105
    EricU
    EricU Well-Known Member
    Englewood, CO
    so i too have vibrations at 60-70mph, got under my truck and grabbed the drive shaft, i can wiggle it so much that theres 1/4" gap between the bushing and the metal collar and then all the deflection in the bushing itself, for about a max of 1" movement.
    I ordered a Timken CB, but then i got to thinking, if im pulling the drive shaft, should i go ahead and swap ujoints too? i have about 156k miles on the truck, and the previous owners likely did not grease them as it took a few pumps of my grease gun to fill the u joints up. If thats a wise idea, what brand U joints should i get? also what type of grease is best?
  6. Jul 29, 2015 at 9:41 PM
    #106
    wolverine8
    wolverine8 Well-Known Member
    MV
    06 Sport 4X4 - SR5
    Stock
  7. Jul 30, 2015 at 12:20 PM
    #107
    Pugga
    Massachusetts
    Certainly not a bad idea to swap the ujoints while you're in there. I would go with Spicer ujoints, just like OEM. Make sure you mark the drive shaft to keep everything phased the way it was prior to the repair. I used a punch to mark the drive shaft and flanges so they all fit back together the same way.
  8. Aug 2, 2015 at 8:36 PM
    #108
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    changed mine just the other day and after I got new one put on and i was throwing old one out i found a small washer inside up against the inside race (hidden in the old grease). The driveshaft spins freely but i can hear it squeaking and it gets pretty hot. What side does that little washer go on?
  9. Aug 8, 2015 at 1:23 PM
    #109
    devinzz1
    devin
    2023 aclb trd or mt
  10. Aug 8, 2015 at 2:29 PM
    #110
    EricU
    Englewood, CO
    i put those washers on the rear side of the bearing, no idea if its correct but i have no issues, i did mine last night. also did the front and rear u joints, vibration free now.
    Dave21ish likes this.
  11. Aug 8, 2015 at 2:48 PM
    #111
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Toyota calls them "spacers", there are two. One on each side of the drive flange.
    From the support bearing inner race rearward it goes...........race>spacer>drive flange>spacer>nut
  12. Aug 11, 2015 at 11:14 AM
    #112
    Manwithoutaplan
    ID
    Great write up OP :thumbsup:
  13. Aug 12, 2015 at 9:37 AM
    #113
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Ordered up a new bearing and nut today as I noticed a squeaking noise developed over the weekend. I don't have much play and no vibration issues, just a little noise. Would it be alright to hit the trails tonight with a little noise coming from underneath or should I wait until after replacing the bearing?
  14. Aug 12, 2015 at 10:05 AM
    #114
    devinzz1
    devin
    2023 aclb trd or mt
    run it.
    TNToyo79 and alee891[QUOTED] like this.
  15. Aug 12, 2015 at 10:12 AM
    #115
    alee891
    Austin
    Black Hills
    Tacomaless
    That's what I wanted to hear!:burnrubber:
    TNToyo79 likes this.
  16. Aug 12, 2015 at 10:21 AM
    #116
    Dirty Pool
    99 XCAB V6 MT TRD
    Just for the heck of it, grease all 3 fittings on the drive shaft "Double Cardan" joint just to the rear of the support bearing. The "center ball" in the DC can make a squeak identical to a failing SB.
  17. Aug 12, 2015 at 10:28 AM
    #117
    alee891
    Austin
    Black Hills
    Tacomaless
    I greased up the entire drive shaft last night in hopes that the squeak would go away. All ujoints looked fine and appeared to push grease out. When I gave the drive shaft a tug I noticed the squeak was coming from the center bearing. I couldn't visually find any issues with the bearing, but figured it hasn't ever been replaced so it would be something for me to try out.
  18. Aug 20, 2015 at 1:22 AM
    #118
    Dave21ish
    Dave21ish Member
    02 4 banging turd
    Hahaa purrrrrrfectttt i was just about to give up looking for this answer :)))))
  19. Aug 22, 2015 at 9:56 AM
    #119
    Joe_from_iowa
    Joe_from_iowa Well-Known Member
    Joe
    2001 Tacoma TRD
    Just changed mine today! Thanks for the great instructions!!!
  20. Sep 8, 2015 at 5:52 PM
    #120
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    A little info to impart. Timken HB31 and the National center support bearing that ironically shares the same part number are both made in or at least assembled in China, and though the bearing itself may be decent and made by a U.S. manufacturer (still doubt that) the rubber surrounding it is crap, feels too soft and I've heard a lot of people say it doesn't last. Unfortunately I've read the replacement oem ones don't last as long either.
    I put a National one from oreilleys (they now sell Anchor) under my truck a few months ago, I plan to pull it and take it back before the year warranty is up to maximize my cost
    I read one guy had an idea to drill a hole in the rubber and inject it with silicone, I'm thinking about doing this. The rubber is just a pillow or cushion and the bearing is inside. The silicone would need to dry thoroughly before being used though or it would likely squish out.
    For those that have questions about acceptable movement in the bearing itself, it should be obvious in the fact if it's bad it will feel like the driveshaft has unimpeeded slop or it will jiggle, meaning the rubber cushion around the bearing is toast, usually the bearing itself inside the rubber lasts longer than the rubber bushing. When the assembly is still good you can push on the drive shaft but it will feel like the driveline is solidly surrounded, no jiggle so to speak.
    For those who shim your center support bearing down, my experience is this helped kill my original bearing. It tilted the bearing in the rubber cushion and put added flex inside the housing as the driveshaft was tipped down to improve the angle at the double cardan joint. I left the spacer out and haven't had any vibes. As someone mentioned before, axle shims are the best way to relieve the angle at your pinion and take stress off the double cardan joint.
    The last thing I'll offer is I tried to put it a Hendrix motorsports driveshaft support bearing on a custom welded mount I made out of steel c channel. It reuses the stock bearing from the center of the stock center support bearing, you have to tear it apart to get it out. image.jpgThe vibration almost shook me out of the truck at 40 mph, so unfortunately we're stuck with cheap options or paying $150 for oem which is the best option imo, other than going to a one piece drive shaft which I'm not interested in doing
