How To: Replacing Carrier Bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJPP, Jan 27, 2013.
  1. Sep 9, 2015 at 9:56 AM
    #121
    FlyingCitrus
    FlyingCitrus New Member
    Tina
    1998 taco 4cyl Ext cab 4WD 420,000
    Hell Creek 4+1 rear springs
    421,000 miles and counting... Grease all her joints etc every 10-15K since new and Mobile 1 only.... Center bearing is way wobbly and can see bearing race through rubber... with a 12 hr one way ride in 3 weeks and back... looking at where to get the bearing for a good one.. OEM is option as I like doing it right the first time... and this one has lasted this long. wobbles at 55 just a bit.. thought it was a rim out of round which I do have but yea right in center... Any up do date comments on best place to get part.. OEM from Yota dealer or other...
    Tina
    4WD and Laxtoy like this.
  2. Sep 9, 2015 at 10:01 AM
    #122
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    Send a PM to Camelback Toyota (Vendor) for a quote. They will likely be much less than local dealership.
    Bennett707 likes this.
  3. Sep 9, 2015 at 12:03 PM
    #123
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    410,000, that's awesome
  4. Oct 3, 2015 at 10:17 AM
    #124
    PrerunnerVsix
    PrerunnerVsix Well-Known Member
    Ali
    Houston, Tx
    2013 Tacoma TRD Sport
    anyone know the part number of the flange nut?
  5. Oct 3, 2015 at 11:58 AM
    #125
    Laxtoy
    Maltby, WA
    90179-18009
  6. Oct 5, 2015 at 7:30 AM
    #126
    09Tacomania
    09Tacomania Well-Known Member
    Scott
    Little Rhody
    09 Silver Streak Dbl cab 4x4
    Icon CO's, LR UCA's, Icon rear 2.0 rear resi's, Wheelers 1.5" 3 pk aal, blacked out badges, Andre's devil horn's, Extang tonneau. Oem racks
    is that part # 1st gen specific or for 2nd gen..... I need the part # for 2nd gen. Thanks
  7. Oct 5, 2015 at 7:55 AM
    #127
    PrerunnerVsix
    Ali
    Houston, Tx
    Im guessing 1st gen
  8. Oct 5, 2015 at 5:13 PM
    #128
    Laxtoy
    Maltby, WA
    1st gen. This is a 1st gen specific thread, there are a lot of different options for carrier bearings for 2ng gens, guys I've read using McMaster Carr bearings, search wookie strength carrier bearing, you'll get some interesting ideas
    OG_Tacoma likes this.
  9. Nov 4, 2015 at 3:06 PM
    #129
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Thats awesome Tina..:thumbsup::thumbsup: & underscores what I've preached here for years about being anal about lubing everything with a zirk that needs grease.
    I don't know but I've put CB's spec'd for 1st gens on 2nd gens & vice-versa so regardless of part #, I'd say it's the same part (physically)
  10. Nov 24, 2015 at 8:23 PM
    #130
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    Just did this last night, 11/23/2015, and wanted to share my adventure. was surprisingly easy, took about an hour. my trucks also a 4x4, so after I removed the rear drive shaft completely, I put it in 4hi and drove away as though it was a front wheel drive :-D. the flange on the tranny/x-fer case was held in by a locknut. so it wouldn't fall out or leak any gear oil. I used just a 14mm wrench and 14mm universal socket on a 3/8 drive cordless impact gun. at least until I got to removing the support, i went to my work for that.
    just like it says in the how-to, marked all yokes to their flanges with a blue metal marker, removed the yoke from the flange at the rear diff first, unbolted the bad carrier bearing from the crossmember, then removed the front yoke from the tranny/x-fer case flange. had to do some prying with a drywall hammer to remove the yokes from their flanges, wasn't hard though.
    then using my tail gate as a work bench, I separated the 2 halves of the driveshaft and drove to my work, which coincidentally has a machine shop :-D. when I got there, I placed my forward half in a bench vice with the support end sticking out to work on. I was about to use a 3/4 impact gun to remove the nut without prying out the staked/locking piece, but my toyota buddy yelled at me saying I need to open it up first...... Which was weird cause the head machinist never does that, he just uses the impact gun and zips those nuts right off with the staked portion and threads still in tact. anywho, the staked piece was being a pain for 5 minutes so my buddy said fuck it and just remove it like I was going to. took less than a second with the nut and threads in perfect condition!
    here's the next weird thing though. when we went to remove the bad carrier bearing, it just slid off! it wasn't loose fitting or the wrong one or anything. it just came off with a little force. and the new one went on just as easily! it was a perfect fit! we had to dig our heel into the ground to give us some pushing leverage, but it still went on all the way. weird?
    so i then drove my truck back to my buddys house and reversed the process, making sure the marks I left matched up. overall took about an hour, driving included.
  11. Nov 24, 2015 at 8:49 PM
    #131
    samiam
    Sam
    Stinky Vegas
    Nice job. What were the symptoms of your bad CB, and what brand did you replace it with?
  12. Nov 24, 2015 at 9:42 PM
    #132
    CodeSeven
    Serge.
    Coachella Valley
    symptoms were loud squealing as though the belts were loose. but only between 30 and 55 mph. happened while accelerating, cruising, or decelerating between those speeds. knew it wasn't the belts because I would push the clutch and the noise would continue. if it were the belts, the sound would be consistent with the engine RPMs, not the velocity.
    and it started making a lot of noise the day after I changed my tranny mount. weird thing here. the rubber on the mounts were almost 1 inch lower than stock. so with the old tranny mount on, I pushed on the drive shaft to check CB play, it was tight. I guess the tranny sitting lower than stock tugged the drive shaft down, making the CB seem good and tight. after changing the tranny mount, the play in the CB was apparent.
    diagnosed the issue for a week. and in the mean time i did stuff like remove my rock guard, spare tire, checked my body mounts, my leaf springs, my tail gate, my exhaust heat shields, everything was good. I even sprayed permatex's rubberized undercoating on everything I just mentioned except for my tail gate. noise continued. on a plus note, my truck is now quieter than it ever was :D.
    I can't remember the manufacturer of my bearing. all I remember is it supplied with our main bearing line at my work. carquest/advance auto parts. I didn't want to do a dorman or anchor center support, since they don't specialize in bearings like koyo, timken, skf, or NTK.
    side note!! I also lubed my u-joints and rear driveshaft slip yoke while I was trying to figure out where the noise was coming from. doing this made the squealing go down about 90%, affirming my suspicions that the CB was bad. I'm also going to assume the noise died down because my u-joints were a bit stiff/dry, and lubing them allowed them to move freely
    _swede and samiam[QUOTED] like this.
  13. Nov 24, 2015 at 9:54 PM
    #133
    samiam
    Sam
    Stinky Vegas
    Thanks for posting that info. I first replaced mine with an SKF unit and its quealed from the start. Then tried the Dorman and it was garbage. I have an Anchor unit on there now, and all is well after 5K miles.
  14. Dec 5, 2015 at 4:13 PM
    #134
    emanuelr15
    emanuelr15 Active Member
    emanuel
    1998 tacoma 2004 Tacoma
    thanks alot for this ,just replaced it today and it was as easy as one two three .
  15. Dec 31, 2015 at 3:55 PM
    #135
    sk2853
    sk2853 Member
    North Bay California
    04 Tacoma Double cab
    It gets washed on occasion AND...upgraded dome light!!!
    Just replace my center bearing on my 04 dbl cab 2 wheel drive, with 140k, this afternoon. The truck is used, but new to me, and while going though my bumper to bumper to check, I found the center bearing had a 1/2" of play. I have been experiencing what I believe to be (after reading some more great write ups on this forum) "axle wrap". When accelerating from a stop, I more often than not, get a clunk from the back. I bought and installed a set of leaf spring clamps a couple of months ago and purchased the OEM center bearing which I put on today. The job took about an hour with the only issue was removing the flange from the splines on the driveshaft. Had to use a puller and tap the flange with a hammer to get it to budge. The splines were dry and gunked up. Once I got the flange off, the center bearing just lifted off. I did use a 1/2 drive battery powered impact with an impact swivel to get the 14mm's loose and to remove the 24mm for the flange (did not need a vise). Re-greased everything and re-installed the drive shaft. No more play in the center bearing! No issues on the test drive, got up to 75 with no vibrations or noise.
    Thank you for the amazing write up! Made the job easy for me!
    ClevSix likes this.
  16. Jan 5, 2016 at 9:24 PM
    #136
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    God, I love TacomaWorld. I'm about to perform this replacement myself. I always look for a how-to thread on TW so i will know what I can expect. Nice write up. :thumbsup:
    Oh, and I'm replacing mine with a Timkin unit I got from Rockauto for ~$68. I don't really have the cash to burn for the OEM mark-up, but I always try to stay with either the OEM manufacturer (Koyo, Aisin, Denso, etc...) or a good well known brand like Timkin or Moog.
  17. Jan 28, 2016 at 9:45 AM
    #137
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Question about u-joints are they pressed in on a 2000 Tacoma? I didnt see any snap rings on the one side but I havent looked at the opposite side...
  18. Jan 28, 2016 at 9:56 AM
    #138
    Taco No Baka
    Lee
    Tampa, FL
    If you're talking about the ujoints on at the transmission/t-case or the rear diff, the c-clips are on the inside of the yoke like the axle ujoints on Dana solid axle knuckles. The double ujoint by the support bearing...I don't think those are replaceable, at least that's what I've always heard, but the ends connecting the unit to the driveshaft and propeller shaft probably have the c-clips on the inside as well.
    Hope that helps.
  19. Jan 28, 2016 at 10:00 AM
    #139
    wilcam47
    Will
    Bourbon state
    The cardan joints are able to be replaced as far as my search goes. The Joints I was talking about are the one connected to the axle/pinion and the part off the rear transmission. I'll look later but the caps from the outside didnt have any snap rings so maybe they are internal like you said.
  20. Jan 28, 2016 at 10:06 AM
    #140
    Taco No Baka
    Lee
    Tampa, FL
    Alright. My manual says not, but I was always suspicious of that anyway. I mean, why shouldn't they be replaceable? It hasn't been an issue for me yet, so I haven't really looked into the alternatives. :cool:
    But yeah, for the others, they are definitely on the inside of the yoke unfortunately. The good news is, IIRC, you can get a yoke for the external style clips if you wanna cough up the cash. :thumbsup:
