How To: Replacing Carrier Bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJPP, Jan 27, 2013.
  1. Jan 28, 2016 at 10:53 AM
    #141
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    not really looking to do that lol. I got a Haynes manual coming in the mail so maybe that will answer some of my questions. Im new to this forum so its going to take a while to search different things.
  2. Jan 28, 2016 at 11:04 AM
    #142
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Yeah, the Haynes manual kinda sucks. It's good for torque specs and such, but it tries to cover too many vehicles and thus can be hard to follow. Not only that, it it arbitrarily determines for you whether or not something might be too technical, or the equipment too costly, for the DIYer and then leaves any information on it out. Case in point the diffs; it gives you no torque specs on the ring gear bolts or the carrier bearing bolts or any procedures for taking apart the front clam shell housing. The fact is, this forum is a much better DIY reference than the Haynes manual. :cool:
    quetzal likes this.
  3. Jan 28, 2016 at 12:13 PM
    #143
    wilcam47
    Will
    Bourbon state
    I have the center support bearing on order...so once I get the part to my house hopefully it all goes well. I'd like to replace the u-joints too...I just have to find the right part #s for my truck...*sigh*
  4. Jan 28, 2016 at 12:34 PM
    #144
    Taco No Baka
    Lee
    Tampa, FL
    Heh, mine was a breeze, it was so worn out. I didn't even have to use a puller on it. It fell off in my hand once I had it unbolted. One thing I did differently than most how-tos is I left the propeller shaft connected to the transfer case. I didn't take it all the way out. That way the engine held the shaft while I torqued the flange nut. I put a ratchet strap around the support bearing end of the propeller shaft to hold it up once the support bearing was unbolted and I loosely threaded the support bearing bolts back in the new one as it was going back in. That let it move while I torqued the flange nut. I know most people find it easier to do that stuff on the bench with a vise, but it was worth doing it under the truck for me not to have to disconnect the t-case flange...that and it held the shaft in a safer manner when I torqued the flange nut.
    underaroof likes this.
  5. Jan 28, 2016 at 12:43 PM
    #145
    wilcam47
    Will
    Bourbon state
    good to know...I dont have a bench with a vise YET....its on my list of stuff...lol So this is a good alternative...
  6. Jan 28, 2016 at 12:46 PM
    #146
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    so going to tackle this on Saturday but on a 2nd gen.. Does anyone know if the torque to set the bearing and nut is the same?? From what I can find the bearing is either the same or pretty damn close, since Rock Auto says it will fit 1st and 2nd gens
  7. Jan 28, 2016 at 12:47 PM
    #147
    Taco No Baka
    Lee
    Tampa, FL
    Haha, then this method is definitely for you. :thumbsup:
    Oh and also of note, I didn't remove the driveshaft from the diff either. I just split it at the center support flange and wired it up out of the way to the side. And don't forget to use blue locktite on the flange bolts when you go back together. :cool:
  8. Jan 28, 2016 at 12:48 PM
    #148
    Taco No Baka
    Lee
    Tampa, FL
    I couldn't really say. I would imagine there's more than a few threads on this for the 2nd gens that will tell you though. :thumbsup:
  9. Jan 28, 2016 at 12:49 PM
    #149
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    didnt have to use a puller on mine neither
  10. Jan 28, 2016 at 12:49 PM
    #150
    jztacoma
    Upstate NY
    Semi Stockish
    so far not getting any luck, mainly Vibe issue questions and such, not much for replacement. Keep hunting though :thumbsup:
  11. Jan 28, 2016 at 12:52 PM
    #151
    wilcam47
    Will
    Bourbon state
    The way my luck goes I'll need a cutting torch to remove mine;) Cross my fingers and hope it comes out easy....
    Taco No Baka likes this.
  12. Jan 28, 2016 at 1:03 PM
    #152
    wilcam47
    Will
    Bourbon state
    Im no expert but Id venture to say its prob the same torque.
  13. Jan 28, 2016 at 1:19 PM
    #153
    Taco No Baka
    Lee
    Tampa, FL
    Haha, every time I assume something is the same on 2nd gens as it is on 1st gens, it turns out to be wrong. I don't assume anything anymore, especially with this since the driveshaft arrangement on a 2nd gen is completely different (the slip yoke is on the t-case/transmission instead of at the diff which seems really stupid with the support bearing in the middle, but oh well).
  14. Jan 28, 2016 at 1:23 PM
    #154
    wilcam47
    Will
    Bourbon state
    yeah this cardan yoke thing is all new to me....why would something be made like this??lol I like the old style of u-joints pressed in where you take it to a bench and use a socket, hammer and block of wood to get the old u-joint out and also NO marking of which position the yoke came out otherwise its imbalanced:frusty::crazy:
  15. Jan 28, 2016 at 1:32 PM
    #155
    Taco No Baka
    Lee
    Tampa, FL
    The double cardan (some people also call this a CV joint) allows for more flex than a single ujoint which is important if your driveshaft is short (or supported in the middle).
  16. Jan 29, 2016 at 10:48 AM
    #156
    wilcam47
    Will
    Bourbon state
    I didnt want to start a thread but is a torque wrench ok if its been sitting a while and it looks like the oil or something has leaked out of it?
  17. Jan 29, 2016 at 10:53 AM
    #157
    Taco No Baka
    Lee
    Tampa, FL
    As long as it's been stored on the minimum setting, you're probably okay (I'm assuming its the click type rather than the beam or dial type). The other types I would imagine are fine too as long as they are resting at zero.
  18. Jan 29, 2016 at 11:01 AM
    #158
    wilcam47
    Will
    Bourbon state
    Thanks, I havent used them in a long time...Im talking years...but I assumed they would be ok. I just noticed one of them had leaked oil out...maybe it was just from being in a hot garage and not being used. Im still waiting on my center bearing part to come in...so I can start that project:annoyed:
  19. Jan 29, 2016 at 11:08 AM
    #159
    Taco No Baka
    Lee
    Tampa, FL
    I would say that either oil was spilled on them or it's just some light preservative lube that wicked out. I don't think torque wrenches are filled with oil so if they were properly stored on the minimum setting (not looser or tighter) then I wouldn't worry too much. If you wanted, you could try to find somewhere to have them tested, but I don't know where you could do that outside of sending them back to the manufacturer to have them calibrated.
  20. Jan 29, 2016 at 2:07 PM
    #160
    wilcam47
    Will
    Bourbon state
    yeah its prob not worth the expense...ie cheaper to get a new one in that case ;) When I was active duty we had to take the torque wench to the highest setting and break it over 6X's before we used them. That way it was consistent. I bought these at Sears many years ago, but I dont know if they have a 100% return on torque wrenches.
