How To: Replacing Carrier Bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJPP, Jan 27, 2013.
  1. Jan 29, 2016 at 2:22 PM
    #161
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Yeah, I'm gonna say not. :D I have a MAC 1/2" drive flex head 30-250ft-lbs one that I bought about 20 years or so ago. If I new somewhere local to take it, I'd have it checked and calibrated, but sending it back to MAC would probably cost me a first born child. It seems to do okay though. I'd still rather know for sure. :cool:
  2. Feb 3, 2016 at 9:57 AM
    #162
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Well my part should be at the post office today....seems like when you are really needing a part it takes forever to get to you...if it was something not so important it gets to you in 2 days...LOL Im guessing it will get to me tomorrow...got to love small town mail ;)
  3. Feb 3, 2016 at 11:25 AM
    #163
    wilcam47
    Will
    Bourbon state
    well surprising to me I got both my Haynes manual and my center bearing. So for the u-joints that have the c-clip inside the yoke is there a special tool to take these off or just use pliers? I havent crawled under there yet to see whats going on.
  4. Feb 3, 2016 at 11:37 AM
    #164
    Taco No Baka
    Lee
    Tampa, FL
    I have yet to have the misfortune to have to mess with mine, so I couldn't really tell you if there's a trick to the inner clips. Try Youtube. There may be a how-to on there that can hook ya up. :cool:
  5. Feb 3, 2016 at 11:39 AM
    #165
    wilcam47
    Will
    Bourbon state
    I ordered some ujoint from Napa so I'll go pick them up tomorrow and dive into this project...
  6. Feb 4, 2016 at 7:47 PM
    #166
    wilcam47
    Will
    Bourbon state
    Success!!...Center bearing changed, front shaft by the trans and back shaft by the Pinion u-joints changed. I left alone the cardan joint just because I dont have a good set part numbers on the ujoints...It looks feasible just not right now. They werent squeaky or have any play in them so I take it as they are ok for now. I greased them and they should be GTG for 50K or so... Greased the new u-joints and the rest of the driveline took it on a test drive and amazingly the loud vibration I was hearing is gone! Thanks for the help...Im glad I found this forum and thread.
    Taco No Baka and CodeSeven like this.
  7. Feb 4, 2016 at 8:06 PM
    #167
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
  8. Feb 19, 2016 at 2:01 PM
    #168
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Going to tackle this over the weekend. I ordered a oem center bearing and Matsuba brand u-joints. Thanks the the write up OP, also to the member that suggested a new flange nut. Wish me luck guys, thanks.
  9. Feb 21, 2016 at 8:54 AM
    #169
    wilcam47
    Will
    Bourbon state
    good luck...its really not bad...
  10. Feb 21, 2016 at 9:56 AM
    #170
    oldschoolbmx
    oldschoolbmx Well-Known Member
    Harry
    02' Tacoma TRD, 14' T4R SR5, 17' Tundra CM Ltd
    Magnaflow cat-back, K&N, B&M short shifter
    This info is really helpful. I did this the week between xmas and new years. The center brg was super easy to replace, but for those who plan to do the u joints as well, those were a PITA.
  11. Feb 23, 2016 at 8:05 AM
    #171
    wilcam47
    Will
    Bourbon state
    did you do the cardan joint in the middle as well or just the U-joints and center bearing?
  12. Feb 23, 2016 at 8:08 AM
    #172
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    Great write up!! Thanks.
    How much play should there be in the carrier bearing?
    Do you think aftermarket is ok or would you suggest Toyota original?
  13. Feb 23, 2016 at 8:12 AM
    #173
    quetzal
    Mario
    Long Beach, CA
    Careful with the double cardan, that is not serviceable. It's best to leave it alone unless you're absolutely sure it's gone bad.
  14. Feb 23, 2016 at 8:12 AM
    #174
    quetzal
    Mario
    Long Beach, CA
    Spend the money once, OEM
  15. Feb 23, 2016 at 8:13 AM
    #175
    quetzal
    Mario
    Long Beach, CA
    Thanks, it wasn't bad at all. I didn't need the puller, though I had rented it from AutoZone just in case.
  16. Feb 23, 2016 at 8:22 AM
    #176
    wilcam47
    Will
    Bourbon state
    well the books tell you it isnt serviceable...some guys on this forum have had success changing the "u-joints" in the cardan...you just have to have the EXACT measurements for your particular vehicle. I know theres at least one thread on it in Tacoma world...
  17. Feb 23, 2016 at 8:23 AM
    #177
    wilcam47
    Will
    Bourbon state
    I used the balljoint remover for the u-joints but my carrier bearing just popped off when I took it apart...
    So you from Guatemala or just like that particular bird? I was born in Guatemala.
  18. Feb 23, 2016 at 9:05 AM
    #178
    quetzal
    Mario
    Long Beach, CA
    I just saw a video yesterday of a guy using the puller to replace a u-joint. It looked pretty easy as he used sockets as well. Is that the method you used?
    And yes, viva Guatemala!!! :D
  19. Feb 23, 2016 at 10:28 AM
    #179
    oldschoolbmx
    Harry
    I did not do the double cardan as all research pointed to just leave it the fuck alone. Upon inspection, it moved freely with no binding so I just greased the hell out of it.
    quetzal likes this.
  20. Feb 23, 2016 at 10:37 AM
    #180
    oldschoolbmx
    Harry
    I went oem since the original center bearing lasted me 130,000+ miles. I also didn't need a puller as mine just slid right off. On another note, the biggest issue I had with the u-joints was after driving the outer race in one direction, I had a tough time lining the other race up with the fit to get it to back the other way. I used a 4" disk sander to grind a large chamfer on the outer race so it would line up easily.
