How to reset and calibrate your VSC computer - The Easy way
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Dec 30, 2016.
  1. May 5, 2022 at 3:50 PM
    #341
    tube
    tube Member
    I don’t think so. From reading other posts here, faults can still remain, but you can still have a successful reset. The fault just stays after the fact. I can’t even get past step 1.
  2. May 5, 2022 at 4:52 PM
    #342
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    The whole system is tied into the ABS ECU under the driver seat. If you have an ABS fault at any of the four wheels then the process won’t work. Check and clear the 94 error first. If it is a short then it will immediately return, a diagnostic check
    of the system doesn’t occur until you exceed 7 mph. After you clear the 94 error then the system will enter diagnostic mode and reset defaults utilizing the process in the thread. If you need to see it then just get an inexpensive TIS setup off
    Amazon for about $30. You can see all the systems as they compete
    the diagnostic check. It will also freeze frame at the point a fault is detected.
  3. May 5, 2022 at 5:15 PM
    #343
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    My ABS ECU is part of the ABS module in the engine compartment....not that it helps but...the more you know.
  4. May 5, 2022 at 6:01 PM
    #344
    zippsub9
    Halfmoon, NY
    14 DCLB
    That is an actuator module with an ECU attached to it. The LRU under the driver seat measures the yaw and pitch that he is trying to reset. I should have been
    more specific. All of them together are part of the ABS system as a sub component of the VSC system.
    SR-71A and Airdog[QUOTED] like this.
  5. Jul 19, 2022 at 4:52 PM
    #345
    jharlam
    jharlam New Member
    This thread is why I love TW. Worked like a charm
  6. Jul 28, 2022 at 3:31 PM
    #346
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    After my truck almost killing me twice today, decided to give this a shot. :fingerscrossed:
  7. Aug 1, 2022 at 8:33 AM
    #347
    gti2taco
    gti2taco Well-Known Member
    Brian
    Va Beach
    14 trd offroad, stock
    Hey has anyone been able to do it before, but not now? I lifted my truck in 14', and this worked great. The lights triggered again after I adjusted my coilovers, and I can't get it to work again. Help me Obi-Wan, you're my only hope.
    jharlam and OZ-T like this.
  8. Aug 10, 2022 at 9:55 AM
    #348
    jharlam
    jharlam New Member
    Assuming you tried this already but the key for me was level ground. I did it twice and it worked for a little only to have the light come back on. After finding the most level spot I could and doing it again I've been good with the lights off for 500 miles or so
  9. Oct 14, 2022 at 11:32 AM
    #349
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Changed from 16" to 17" wheels and started to get issues. (Front wheel braking when corning) Did the re-set a couple times but hasn't worked. The last time I did it on my flat garage floor so not sure what else I can do...?
  10. Oct 15, 2022 at 7:33 AM
    #350
    Dr.JohnZoidberg
    Dr.JohnZoidberg Member
    2013 Tacoma TRD off-road
    This is exactly what I needed after I replaced the suspension on my 2013. Easy and to the point. Took me 2 minutes
  11. Oct 22, 2022 at 3:36 PM
    #351
    Whitesands
    Whitesands New Member
    2012 Tacoma
    Offroad
  12. Oct 31, 2022 at 8:39 AM
    #352
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    My TPMS wasn't set to the new wheel sensors so that light was on. However, that has been fixed now. I haven't been in a situation to test it again since that. But my alignment is so far off that I'm having to get another one done after new LCAs and cam bolts are installed on Wednesday.
    I will re-set everything again and report back after everything is fixed.
  13. Nov 30, 2022 at 6:12 PM
    #353
    dsmckee
    dsmckee New Member
    Awesome post. I took my truck to get an oil change and the technician stalled out super hard (manual transmission) on my 2015 Tacoma coming out of the service bay. This triggered the slip indicator light. After a back and forth with the technician, and checking for a diagnostic code with their computer (their computer didn’t give a code), I went home and googled the issue. After finding this forum, I tried out the solution and got rid of the slip indicator light in less than 5 minutes. Thanks again.
  14. Jan 1, 2023 at 1:41 PM
    #354
    Turboxer
    Turboxer I call her El Taco
    Springfield, Mo
    12' DCSB TRD O/R
    Had some UCA’s installed as well as new tires and an alignment and I tried this.
    I can get the ABS and slip light to blunt during the rest process but when I do step 3 and leave it in there/turn the truck to on position they don’t blink.
    What am I doing wrong?
  15. Feb 12, 2023 at 10:25 PM
    #355
    Parabellum
    Parabellum Well-Known Member
    North Central PA
    2009 Dcab Man. 6spd v6 Tacoma TRD Offroad elocker
    Thanks for the post really helped me out.
  16. Feb 13, 2023 at 6:04 AM
    #356
    Turboxer
    Springfield, Mo
    12' DCSB TRD O/R
    As a follow up… it ended up that the shop broke an ABS sensor wire and they replaced it for free. All good now
  17. Feb 13, 2023 at 6:05 AM
    #357
    Parabellum
    North Central PA
    That would do it.
  18. Feb 13, 2023 at 6:24 AM
    #358
    HoboDave
    David
    Carlsbad, New Mexico
    2023 Toyota Prius
    There's a little black spot on the sun today
    It's the same old thing as yesterday
    There's a black hat caught in the high tree top
    There's a flag pole rag and the wind won't stop
    I have stood here before inside the pouring rain
    With the world turning circles running 'round my brain
    I guess I'm always hoping that you'll end this reign
    But it's my destiny to be the king of pain
    - The Police
    Judge: “Do you have a police record?”
    Me: “Yes, your honor…Synchronicity…1983”
    :rimshot:
    Sting has been kidnapped. The Police have no lead
    :rimshot:
    Thank you. Thank you very much. I’m here all week.
    :humble:
    Random music trivia…
    Sting wrote King Of Pain while staying at the Jamaican estate known as Goldeneye. It’s previous occupant was Ian Fleming. He wrote his James Bond novels there.
    Good morning whateverers :pccoffee:
  19. Feb 14, 2023 at 5:56 AM
    #359
    Slashaar
    Josh
    Kansas City, MO
    Update: Much better, still tries to kill me, but far less frequently.
    Stompson likes this.
  20. Mar 14, 2023 at 9:16 AM
    #360
    strmtrooper1
    strmtrooper1 Well-Known Member
    Jeff
    2015 TRD Sport DCSB
    OME Lift, 33" Goodyear DuraTracs
    This worked awesome! The light was on after an alignment...shop "reset it" came back as soon as I started driving.
    With your reset it's been out for good (I hope)
